  • 1 month later...
  • 1 month later...
Hi all,
Just got tuned by Dr Drift, now got 266rwkw. Still got standard clutch and tonight i got a taste of a slipping clutch. Jim's clutch's sound good, pretty keen to get one. I live in Tas and want to know if anyone has any suggestions who i should get to fit it (in tas), and any ideas how much the labour would be?
Cheers
Where abouts in tassie are you?? I work at chris colgrave automotive in launnie, i fitted WHITER33's clutch. The GTR's arent a 5 minute job to get the box out, you'll probably pay upwards of $350 just in labour but could be more. Jim usually supplies a rear main seal and input shaft seal aswell.
Edited by shane_180sx
Hmmm old m8 Jim sounds like he is def the man in the know...booked in a dyno tune today, as ive just had a couple more bolt on's added,
and was told to expect anywere from 330-350 awkw's.
and my clutch was slipping consistantly b4 the new mods, so i might give Jim a ring and see what he has to say and i'll post the results... post/prior, instulation/purchase or all of the above.
thanx for the advise guys :laugh::)
Edited by Borgs
hey im in WA and my clutch is blown. after reading everything about jims clutch my mind is made up.. want to get a lightened flywheel as well. can jim supply as well or any one no of a place in WA that can supply a decent flywheel??? and a reasanable price for install??? any suggestions
my clutch and flywheel will be going to jim very soon. speak with him and u will get all of the infomation u need. he is gonna lighten the flywheel when he does my clutch up. he wants the clutch flywheel and all the crap with them. grease and all. totally agree with other ppl though, when u call, allow a good hour or more! :P
  • 3 weeks later...
I'm not too keen on flywheels that have been lightened as opposed to flywheels that are manufactured lighter than standard. I know of more than one that have gone bang. I don't think it's the skill of the person that lightens them though, more the imperfections in the original flywheel that come to the fore when it is lightened.
  • 1 month later...
I need to decide whether to use Exedy light flywheel (currently in standard clutch) or the factory flywheel with my new Jim Berry Clutch?
Jim reckons light flywheel is bad for drag racing as it makes hard to control wheel spin.
Can anyone advice on this issue?
Hi Jason, what are you mostly be going to be using your car for? I remember you telling me about the setup you had and even though it wasn't a proper tune when you took me for a ride it was still pretty beasty.
I've read alot about clutches lately and some say that when upgrading to a clutch with a higher clamping pressure plate, you should get a stronger flywheel too. So if you don't want the problems of a light flywheel just get a heavier stronger flywheel .
Andy, it is still my everyday car so driveability is a priority. This Exedy light flywheel I have is only good for track work or drift I reckon, the revs drop too fast between gear changes and I dont think it gives any advantage across the quarter mile too.
I got the 3600lb clamping pressure Jim berry clutch on order, was thinking of using the factory flywheel on it. But now that you have mentioned it, how or where do I obtain a stronger flywheel? From what I have heard the Nissan factory flywheel is pretty tough being cast iron, which is whats required by ANDRA if you are running 10s passes, not that I will be doing that sort of time anytime soon but good to know nonetheless.
i have got a one of jims clutches in my car now. had it for a month and it is a very nice clutch to do my daily driving with. i got the full monty he does and is as light if not lighter then the stock clutch.. however grabs incredibly well. the lightness makes daily driving much more comfortable then have a brass button or something like that... i would def recomend
...the Nissan factory flywheel is pretty tough being cast iron, which is whats required by ANDRA if you are running 10s passes
I don't get this bit, Cast Iron can and does crack at high loads and high revs, billet steel is a safer way to go. As ben how safe a standard cast flywheel is
bit the bullet and bought a ORC pro carbon twin today on recommendation from a few D1GP mechanics so we will see how good or bad these puppies really are. Im lazy so i dropped it off at CREATD so we can use the hoist :)
Edited by URAS
bit the bullet and bought a ORC pro carbon twin today on recommendation from a few D1GP mechanics so we will see how good or bad these puppies really are. Im lazy so i dropped it off at CREATD so we can use the hoist :domokun:
fark that certainly woulda left a nice hole in the pocket! :domokun:
keep us informed of how it goes, and what u use the car for :)
P.S lazy kent :P
That's the same setup I had along with a 600bhp engine and 1 too many 8000rpm clutch dumps resulted in my flywheel ending up in the crowd. Hold off another month and buy yourself a new flywheel from japan and get them to fit it at the same time, won't cost much more. Sure 99.9% of people use a standard flywheel or even a standard lightened flywheel (like my new gtr has) but this is 1 problem that can be easily avoided.
I was still only in the low 12's and it happened so I would use their rules as a guide.
Thanks for sharing, maybe I should stick to the Exedy light flywheel thats already in the car. Not sure of its material though, only says "lightweight aluminium and alloy metal" on their website. How does it compare to a billet steel one?
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
