Just ordered an organic 34 GTT clutch with 3300lb of clamping force. Should be fine for 250rwkw (hi flow turbo). Quoted $935 exchange delivered plus $275 deposit until I return my one.
Standard clamping force is 1600-1700lb and they have roughly 140-150rwkw stock, so double the clamping force is roughly double the power. So should handle ~280rwkw.
Cant wait to see how it goes! Sick of the revs flaring under a hard 1-2 gear change :)
put a jim berry clutch in my car just on a week ago now and it is the best clutch iv'e ever driven on, it's a single organic and it's street car friendly but it grips real well too, good customer service, i think it's good too put your trust for a product into a person who's had the experience a guy like jim has had
Cant wait to see how it goes! Sick of the revs flaring under a hard 1-2 gear change :ninja:
Ok got the clutch installed yesterday. After copping lots of abuse from the japanese mechanic about why I didnt just fit an exedy HD clutch. He kept saying that I fit another standard one, I kept saying no its not standard etc etc.
Whatever, so I jumped in the car and first of all thought they hadnt actually changed the clutches cause it felt the same as standard driveability wise. Drove sedately for a while and yeah the gripping point is very slightly narrower but not noticeable. The driveability is sensational.
Then came time for the real test, gave it some stick in first and went to do a quick change to 2nd, clutch grips and the rear wheels start spinning / axel tramping! Mind you I only have 190rwkw so Im not testing it out power wise but what a difference.
I have put more power to the side now, next issue dam AXLE TRAMP!!
So far the clutch is exactly as promised, very happy. Dont listen to silly mechanics!
  • 1 month later...
After plenty of reading on a clutch upgrade for 250-260rwkw for street/occassional drag runs (just to see what the power feels like legally :cool: ), I just want to know what the difference between a button clutch and a jb clutch (single plate?) is..
My ATS Twin Plate Rebuilt by JB is in transit, after speaking with Jim I'm sure it will do everything I want it too for a very long time.
Come with insurance in the form of Front Gearbox Seal and Rear Main Seal,
Awesome to deal with and Quick turnaround!!!
I've heard very good things about the nismo coppermix, I am still a massive fan for the jb full monty :thumbsup:
I'm running 405awkw with 930nm and this single plate with 4400lbs pressure plate holds like my os giken triple plate and exedy twin plate BUT drives almost like a factory clutch!
I will never buy another multi plate clutch, dreadful to drive...
  • 3 weeks later...
i spoke to jim berry last week, told him my plans with the car etc and he recomended an organic plate with 3800 lbs clamp load
i told him i wanted a street friendly clutch that could handle 300awkw for the future/no track use
great guy to deal/talk with, got the clutch coming end of next week :)
  • 3 weeks later...
Had my full monty for about 6 months now, got about 350awkw on high boost. Have never really challenged the clutch, never dumped it, hasn't seen a single track day so just day to day street driving. First launch (low boost) it died, I too am very very disappointed...
that is surprising - did u install the clutch?
one of the tricks is to use graphite powder for the thrust bearing slide rather than grease as directed by jim berry...have u spoken to jim about this?
im sure if its a mechanical fault he will look after u
I have spoken to Jim and he was quite helpful but the conversation was predominantly about fault finding the clutch issue which I documented and provided the clutch specialist who installed the clutch initially. I'm waiting to hear back from clutch specialist as he said he was going to speak to Jim about so we'll see what happens after that conversation...
Definitely sounds like the guy to talk to. I can afford a decent clutch but don't anticipate putting a lot of power through it for a while so I'd like to get something tough enough to handle normal street driving with a fairly stock RB26. Doesn't need to be able to handle massive power yet as by the time I can afford those engine mods I'll probably be due for my next clutch. I just want something reliable ... the one I've got has a firm pedal but I'm used to it now, so as long as it's not worse I'll be happy.
+1 for Jims clutches. Full Monty 4300lbs carbonic 5 puk sprung center, feels like a stocker.
Over a year of absolute punishment with over 500rwhp.
Stock flywheel.
Broken 2 boxes and 1 diff with this clutch :(
When using the "full monty" and driving in traffic do you take car out of gear and take foot off clutch pedal when stopped moving...?
Mine was great I loved it and was raped everytime I drove the car. Would do standing start powerskids in 3rd gear and never slipped (drop clutch in 3rd) and 4th gear clutch kicks @ 100kph.
Shame about the broken gearbox parts..... but was great fun :(
hey guys having a problem with my r32 GTS seems to have slack in the drive train because when im doing 60km/h on constant throttle on flat or down hill it seems to well i gues the best word to deskribe it is bunny hop but it it only slightly still verry anoying i thought it was the diff because i knew it was buggered but new diff in today and all the other clunking has stoped but this problem still persists. i am having slight trouble with the idle control valve thing cant remember exactly what uts called so it could be the engin doing something funny but i realy think it is drivetrain related rather than engin related. any idears? also idle control skrew wound all the way in and i cant get idle any lower than 1500 RPM any idears?
Well, after installing my Jim Berry clutch I figured I'd better jump on the bandwagon. Guys, if you ever do one decent mod to your car, get the Full Monty. Drives so much like stock I almost wanted to rip it out cause I thought it was defective. I don't ever recall my standard clutch being that light. Oh, ok, it takes up as quick as the Exedy cushioned button I had in it but after the initial run in period it is just perfect. Money well spent. At first I was dissapointed when I put the money into Jim's account and half an hour later I get a phone call from someone to say he has a twin plate for me. But as I said, I am so glad fate made things work out the way they did. Take my word for it, spend the money, get a Full Monty.
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
