I got a jim berry full monty like 3800lbs clamping pressure in daily driver skyline been in for like 40 000km mostly highway some day to day traffic and its not bad to drive people who drive comment its much same as a button clutch really but however is enough slip their to take off from getting pulled over without chirping the tryes :yes:
im happy enough with the clutch though i like shuddering around lol
First 1000km seemed the clutch was even more on/off before clutch material wore in.
Also full monty comes with modified throw-out bearing or watever it is exact same feeling as normal clutch in pressing down the peddle just instead of slip just goes bang in lol nice reasurring grab i think makes for amusing watchign when tryes places are trying to put car on hoist for new tryes hahahaha
*note some tire wear may occur from clutch usage lol*
  • 1 month later...
I have a JB mini monty with 3000lb pressure plate and organic clutch plate fitted. The clutch pedal is almost as light as a standard clutch yet it bites hard for an organic clutch plate and is a pleasure to drive.
My FJ20 has 250rwkw and no clutch slip whatsoever. I highly recommend a mini monty if your after a good street clutch.
does jim berry makes clutches suited for drift and will hold 300kw and constant abuse?
i payed 1150 for this nismo clutch and its already starting to slip... and im thinking of paying 1500 for a twin plate orc..
mines going in this week :) much the same spec. not sure exactly what the clamping pressure is but its getting the organic too and will hold 400HP according to Jim.
im sure he would be able to make one to suit. just tell him you want a clutch that will stand up to 300kw constant abuse. might cost a bit more than an orc but not sure. my 'mini monty' or whatever its called is costing me over $800 for a daily driver clutch.
  • 1 month later...
I mite have to look into buying one of these. I had to get a clutch for my liberty b4 and that cost me 1100 and that was just the standard item. Where everyones paying 800 - 1100 for full hard out perfourmance clutches. I wish i bought a skyline sooner
has anyone had a jim berry full monty in thier r32 gtr?
im looking to get one just wanted to know how much they cost and how they perform for daily driving?
i have a 220awkw gts4 with gtr gearbox and extreme flywheel. if that helps.
thanks
  • 1 month later...
Jim Berry clutches after all my search it looks to the clutch to buy. I have several questions :
I have a 1995 GTR with 600whp ....which clutch from JB will work for me ? how much it cost ?
What can I do with the 3rd gear problem in my 5 speed tranny ? How complicated is to change for a 6 speed Getrag ?
I will use the car for drag race and almost everyday driving..... what should be a decent E.T. on the 1/4 mile with 4 radial neova tires ?
  • 5 weeks later...
Hi guys. I almost bought a full monty for my r33 gtst. amongst other things it has a gt3040 running 25psi on high boost so lets just say its not shy on clutches. I was about to buy a full monty after driving a mates but instead i listened to my old man who was a mechanic for 30+ years. I instead went to a clutch builder in lismore called dave write who apparently builds heaps of big hp skyline clutches for workshops in sydney. Anyway for about half the price that Jim quoted iv got a great clutch in my line that hasnt sliped nomatter what i throw at it. After countless 4-5k rpm dumpes with 275/35 18's and 346rwkw all i have had is traction or lack there of.
Happy to demo for anyone any time. Try his phone on 02 6621 6495
Il see if i can find some pics i had of the install.
  • 3 weeks later...
I currently have an Excedy HD single that I was thinking of upgrading with the JB full monty - but decided on the Nismo coppermix twin.
Betz - sorry to hear mate, at least you confirmed the full monty status for a GTR. are you goign to get a nismo coppermix now? sound good by all accounts.
its comming out on sat, not sure on warranty policy (or even if its a warranty at this stage), however.. if it is a failure it wont be going back in, so coppermix twin looks like best option from the research I have done. I cant afford downtime on my car as its a daily driver :P
cheers
Excuse my lack of knowledge..
but can someone explain to me whether a non puck type clutch is effective for a 250-330 rkwk rb25 skyline.
Basically i've been told only about puck type clutches 3 , 5 , 6 etc etc. BUT i was also told about non puck type clutches such as "ceramic lining clutches" which do not have individual pucks (buttons), but unsure if these are ok. Say for example a ceramic lining with 1000kg
I got some info on them here below, but don't understand if theyre ok or generally used?
Ceramic
Of all types of linings, ceramics offer the highest co-efficient of friction at around 0.48-0.55. This means they can be used with a lower clamping force pressure plate as the lining provides the grip. But because of this attribute, they cause a lot of wear on mating surfaces and shudder can be commonly encountered. Ceramics can take more heat than an organic material, but deliberately slipping the clutch tends to burn up the flywheel and pressure plate more than the lining.
its comming out on sat, not sure on warranty policy (or even if its a warranty at this stage), however.. if it is a failure it wont be going back in, so coppermix twin looks like best option from the research I have done. I cant afford downtime on my car as its a daily driver :rofl:
cheers
What's the latest?
my dispatch girl botched the packaging and Aussie post sent it back to me, so it went out today.
Jim should have it tomorrow, its welded together, I spoke to Jim and he said it happens sometimes.... due to contamination
nothing is actually worn or broken, just some dust. no oil or anything.
hoping I will get a call from him tomorrow with some info. I hope anyone following this doesnt take my frustration as critisisim of Jim's work but I was expecting better performance out of it and service life, hope its somthing simple and I get my beast back soon.
lol, scabbing loan cars is the pits, so far have had a Nova, a porker 911 and an Izusu truck! :)
cheers
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
