Just got off the phone with Jim.....wow he really does love a good chat!
Top bloke though, really seems to know what he is talking about.
Ordered a modified R33 GT-R clutch for my 34 GT-T with 3300lbs clamping pressure, whatever that means haha.
Will see how it goes once I get it.
same kit as mine Pavel, I hope you get what you were after with it.
I spoke to Jim today aswel, he is a good bloke and we have a bit in common, I am a fitter and turner by trade so we spent a bit of time on the phone exchanging stories :)
heh
Jim came back to me with contamination as the issue, looks like its not a warranty issue on his end as the unit (apart from welding itself together) is fine, my tuner disagrees on the contamination and is at a loss as to why such a speced unit spun on me and failed but that is another story and to be honest I am not into making this a witch hunt, I just didnt get a good result. :|
Hell if it is somthing to do with my driving maybe one of them could tell me ??! (I told them what I have done to it and what happened, niether seemed concerned that I gave it a few launches)
I dont think I will put this clutch back in my car, my power goals might get put on hold for a bit and I'll go for HD stockie organic.
Hope what I have said doesnt put anyone off Jim's clutches, maybe my unit wasnt a good match for my situation but thats what a forum is for I spose, sharing information.
cheers guys :blink:
Edited by Betz
any oil, grease or silicon in the clutch housing, and old clutch powder. I'd have to check the invoice but I'm pretty sure the mechanic charged me a cleandown fee. Jim supplies seals as part of the kit to try and ensure a clean enviroment for his clutches, fair enough I spose.
I was specified a fitment criteria and my tuner was asked to use no oil or grease (tuner asked me I sad fit as requested by Jim)
Okies,
Have my car back with the clutch back in it.
Jim gave me the confidence to put it back in, my tuner was happy enough after all factors relating to my problem were rationalised.
My situation came down to glycol contamination (thats as close as we could narrow it down to after the car's history was thrashed out)
It feels different, not sure if Jim tweaked it at all but it might just feel different because I have been on other wheels for the last few weeks.
I'll keep you all posted if I have any probs in 5000klm time :(
  • 3 weeks later...
I have questions, with regard to flywheel-
does a manufacturer rated car 180km/h have a flywheel that is designed to handle 100%+ increases in power & driving styles/activities that were never intended for the vehicle to be used for?
If not then should aftermarket flywheels be purchased at the time of clutch replacement?
Should the power requirement to be handled be vastly over estimated at the time of order?
I have been bitten by the mods bug (more kw than 1st intended) and already the clutch I had planned for has had to be changed- luckily my clutch has just started slipping :) so now I got to replace it. More mods on the way too lol
How light is too light for a flywheel- car daily drive, weekend warrior & drift days becoming regular occurrences. (Driver also does not mind wheels slipping :wacko: )
  • 3 weeks later...
car speed has nothing to do with flywheel speed... its connected to the motor so whether ur doing 9000rpm in 1st gear doing 60km/h or 9000rpm @ 400km/h the flywheel is still going to be going the same speed
so yes a flywheel will be fine with more power.
as for clutches.. i have a jim berry full monty clutch with a 5000lb pressure plate on my gtr.. feels like stock :D
enough for 800kw
as for clutches.. i have a jim berry full monty clutch with a 5000lb pressure plate on my gtr.. feels like stock :)
enough for 800kw
Sweet. I think its important people know the ins & out of upgrades and this particular 1 is going to have to be done right first time- dont want to have to pull the box out again :)
With regard to rotational speeds I would have thought the response to this would be obvious, 9 grand is 9 grand regardless, what i was getting at is why do lightened flywheels get such a bagging.
Machined lightening of a flywheel is inheritantly dangerous due to metal fatigue/degredation of years of driving & subsequent abuse. Similarly reusing a 1990's pressure plate that has been resprung, sure new spring fingers but what about being non anti burst(as nissan pressure plates were back then)
Providing Jim has all the relevant info required as to use and manner of operation he will build a suitable clutch for whom ever asks him too
My daily has become a part time track car now too.
My uses for my vehicle are becoming more & more motorsport orientated with regard to smooth transitional track driving although be it fast it has 2b smooth.
Then we get doing everthing wrong for the drift days- clutch kicks etc, very hard on equipment stuff.
& finally Drags. Main objective there is all about goin fast in a straight line with a hard-core off the line type of use & fast shift gear changes
So then my point is to really think about what it is you want to do with your car first, if your goal is 200rwkw then go for a clutch that will handle twice that.
Replace your flywheel with something suited to the final picture also
By a new pressure plate with motorsport in mind.
If stock standard gear was meant to be applied to what we on here use it for then Nissan would have designed these cars with 500 at the wheels and supplied it with its own race service team for upkeep & maintenance
Instead it hasn't and this is why we see fly's & pressure plates try to say hello to the crowd thru the top of the bonnet or thru the side of the gearbox into the cabin.
someting to think about at least :D
Another interesting clutch to look at is this new street clutch from NPC. Newly designed it's rated to hold 1000hp at the tyres. This particular one is going in a 26/30 gt4508 powered gtr.
quick question, im gettin a new clutch installed as we speak and its a clutch sourced by my mechanic. sadly couldnt get the Jim Berry as i dont have enough time to do so. now my mechanic has explained that the new clutch is built by the company that originally made the Nissan clutches :s cant remember the name but its a centrivical (spelling) race spec clutch. he said something about a weighting system that pulls the clutch tighter as the RPM increases. unsure if thats wat centrivical is but it sounds good. ill post up the name and results when i get the car back. but until then, has anyone heard of this type of clutch?
  • 5 weeks later...
another nice clutch is a rebuilt and converted clutch by Direct CLutch in albion. they got me out of trouble with rebuilding an excedy twin which i dropped off yesterday and picked up this morning, legends :laugh:
auss13, Centreforce make a clutch that has weights that move in / out of the diaphram fingers. Its a bit of a wank in my view. It makes sense from an engineering standpoint, however the realistic benefits of a clutch would be slim to none in terms of performance gain.
Pics:
I've used Jim Berry clutches and I think that they are the best single you can get for the money. Once you start talking twin and other multiplate clutches - its a different ball game all together.
Contamination would ruin any clutch, regardless of the cost. Make sure that the installer does the good job - otherwise its money down the drain.
The benefit of a Jim Berry Clutch is that he can re-puck the clutches quite cheaply compared to the outright unit.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
