51OWW Posted January 25, 2006 Share Posted January 25, 2006 Hey all. I've got an rb20det in my silvia. Has: high mount manifold rb25 turbo(Modified to use external gate) external gate (14 psi spring) Front mount 3"exhaust walbro fuel pump sard fuel pressure reg. (Car doesn't drive atm... just has these things fitted) I have an safc 2 sitting in the garage, will the safc be able to cope with this setup? (Will it be able to handle a minimum of 14 psi due to external gate? (Not planning to run more then 14psi on rb25 turbo )) If required, does the safc cope with changing injectors/afm??? Ta. Chris. Link to comment https://www.sau.com.au/forums/topic/103274-apexi-safc-up-to-the-task/ Share on other sites More sharing options...
51OWW Posted January 26, 2006 Author Share Posted January 26, 2006 Bump? Anyone? Link to comment https://www.sau.com.au/forums/topic/103274-apexi-safc-up-to-the-task/#findComment-1901026 Share on other sites More sharing options...
sidewazegtst Posted January 26, 2006 Share Posted January 26, 2006 The SAFC is ment as a piggy back system to trick the ecu and since your using an RB20 ecu you don't need to trick it. It's ment to see boost and to run 270cc injector's which are in your motor. Now those injector's won't handle 14psi for very long as you are just (if not for sure) maxing out the duty cycle and an SAFC won't be able to fix that problem. A boost controller, along with the rest of your set up, will allow you to run 10-12psi ish and be fine. You can wire it in if you want and yes you can add some fuel but only a dyno will be able to determine the correction needed. So if you do install it make sure to leave your LOW & HI throttle maps at 0% +/- as that will have the injector's work normally. If you plan on using larger injector's then YES you'll need some sort of fuel management at that point along with either a dyno tune or a tune from someone with a wideband to make sure your a/f's are good. The SAFC will be fine for injector sizes up to 550cc. Some people have run those with no problems while others have said they can't get the right settings and needed more of a stand alone system. I guess it's all a matter of getting lucky. Well I hope that helped you out and good luck with your project. Cheers B) Link to comment https://www.sau.com.au/forums/topic/103274-apexi-safc-up-to-the-task/#findComment-1901321 Share on other sites More sharing options...
PlasticStan Posted January 26, 2006 Share Posted January 26, 2006 Now those injector's won't handle 14psi for very long as you are just (if not for sure) maxing out the duty cycle and an SAFC won't be able to fix that problem. A boost controller, along with the rest of your set up, will allow you to run 10-12psi ish and be fine. You can wire it in if you want and yes you can add some fuel but only a dyno will be able to determine the correction needed. So if you do install it make sure to leave your LOW & HI throttle maps at 0% +/- as that will have the injector's work normally.<{POST_SNAPBACK}> He can't run less than 14psi because that is what spring is in the wastegate, doesn't matter what you set the boost controller to. If it was me I would go for a PowerFC with some larger injectors, much safer than running everything maxed out. The problem with the SAFC is it doesn't allow any tuning of ignition, infact because you're messing with the AFM voltage, it can result in too much ignition advance, meaning it's always a comprimise with tuning the afr's. Also I'm pretty sure the ceramic exhaust wheel on the turbo would be haveing a very hard time if your running at 14psi all the time. Maybe you should consider a turbo rebuild as well. Link to comment https://www.sau.com.au/forums/topic/103274-apexi-safc-up-to-the-task/#findComment-1901378 Share on other sites More sharing options...
51OWW Posted January 27, 2006 Author Share Posted January 27, 2006 Dont mind if everything is running maxed - as long as it can cope with it. (Dont' want to put it on the dyno, find out something can't handle, buy that thing, put it on the dyno, find another thing etc etc) Would rather just have it all there and ready. Don't want to run more the 14pis. (or less ) I s'pose that it's always going to be a touchy subject as most people get different results etc - so i might just have to bite the bullet and see if the safc can cope with what i want on std injectors, if not - new injectors for me, and an safc will be up for sale with all of 15 minutes dyno use haha... Thanks. Chris. Link to comment https://www.sau.com.au/forums/topic/103274-apexi-safc-up-to-the-task/#findComment-1904032 Share on other sites More sharing options...
LBR33 Posted January 27, 2006 Share Posted January 27, 2006 hey can u plz post pics of how the rb25 turbo is using a external gate Link to comment https://www.sau.com.au/forums/topic/103274-apexi-safc-up-to-the-task/#findComment-1904348 Share on other sites More sharing options...
FATAZZ Posted January 28, 2006 Share Posted January 28, 2006 that safc for sale yet? Link to comment https://www.sau.com.au/forums/topic/103274-apexi-safc-up-to-the-task/#findComment-1904595 Share on other sites More sharing options...
51OWW Posted January 28, 2006 Author Share Posted January 28, 2006 lbfalcon: Kinda hard with the dump pipe on? RSTME: Not for sale yet Comes out of the panel/paint next week, goes in for a tune a few days after that. See how it goes Link to comment https://www.sau.com.au/forums/topic/103274-apexi-safc-up-to-the-task/#findComment-1905550 Share on other sites More sharing options...
Baysidebluebnr34 Posted January 28, 2006 Share Posted January 28, 2006 maybe you should fit some bigger injetors, you should be able to dial them in using the sfac-2, but if you have the bucks to spare then go for the ecu and injectors Link to comment https://www.sau.com.au/forums/topic/103274-apexi-safc-up-to-the-task/#findComment-1905599 Share on other sites More sharing options...
black_32 Posted January 29, 2006 Share Posted January 29, 2006 should easily be able to handly it i ran an rb25 turbo off an r34 fmic gtr fuel pump malpassi rising rate fuel regulator and 3" turbo back on stock comp at 14psi everyday and occasionaly on 16psi and never had an issue so at least with an safc it will be a bit better Link to comment https://www.sau.com.au/forums/topic/103274-apexi-safc-up-to-the-task/#findComment-1906124 Share on other sites More sharing options...
