yeah i just got a soft cloth and rubbed a bit it, tries to wipe it off but it was a bit difficult so i just used a wet cloth and then just dried it off afterwards, came up good i rekon.
predator666:
you get to the bulbs from your engine bay, there is a cover that you just give a half turn to and it gives you access to the globes, have a look and twist the cover of, it should all be pretty self explainitory from there, globes range in price, depending on if you want just normal ones or pretty blue ones, hahaha :P
  • Replies 66
Posted Images
R33_Cam: thanx but, err, yeah, i know how to do that.. I wanna know how i can pull the whole front lens off the rest of the assembly to clean. Sounds like other people have done it.
There are some clips, but i've removed them, and it doesn't come off.
Meguires Mirror Glaze Clear Plastic Polish - works best - takes it off easily and it doesnt build up again for a while after. Bought it in K-Mart auto but anywhere that sells Meguires should stock it - from memory its not terribly expensive either. Haha i saw that a lot of the cars had frosty lights at the last cruise and quite a few ppl asked me what i used.
  • 3 weeks later...
If u ever wana get em off put em in the oven for a few min without letting them melt till the goo stuff goes soft n rip em apart
then jam it back together and put it back in for another few to hardend the goo again
werkd for me
but dont try it if u dont trust ureself :(
I hit mine with cutting compound, works a treat.
Don't bother doing it by hand as it wont last long.
I had a friend do it with a very fine polish/cut compound, worked but did not last.
This time I insisted he use the hardest cutting compound he had.
Have a real close look the plastic is very thick.
I also replaced my bulbs with Phillips Opti blue, about $80 a set including parkers.
I found that when I pulled the parkers out they were stuffed and just crumbled in my hand.
Have the problem where I have had condensation on the inside of my lights leaving nice dirty streaks inside... so mine will be going in the oven soon.
Some ppl's lights look really clean but at night u can tell if they have had the inside done too, as heaps i have seen have the same streaks.
My soarer came in and the plastic had almost gone pearly. Had some old kitten cut & polish in a tin at home and it made a huge diff. Finished off with meguires plastic polish
  • 1 year later...
The parking/side lights come out from behind the headlight - the same as the low/high beams... you put your hand in there (hope you dont have big hands) and very akwardly twist it about 1/4 turn, and it comes out, you put your new globe in, and put it back in, with a 1/4 turn and done :D
takes a bit of patients and a few cramps in the hand from the akward angles :D
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
