cheapo lights are around $7.50 a bulb. Toothpaste is an abrasive so it makes sense that it would clean the plastic... I've heard it being used to polish other things too, but cant remember.
I polish my glasses with toothpaste once a month.
Sorry. I'll go now.
  • Replies 66
Posted Images
  • 1 year later...
I had some overspray on my headlight and cleaned it off with thinners.
What a farken mess! looked like wrinkly skin.
I tried cutting polish, that just made it shiny but didnt get rid of wrinkles and realised I'd really farked up. Tried Auotsol that worked but it was gunna take ages to get rid of all the wrinkles so I stepped up a notch and tried Gumption, that worked better but still a long way to go, until I used a 3m pad with the gumption. That worked really well, still took a while but only 1/2hr,but I to continually clean the pad because it built up with bits of plastic pretty quick. I then cleaned with water and spayed silicon spray on it and it came up a beaut.
If you look at my avitar you can see how farked it was.
DONT DO THIS UNLESS YOUR PLASTIC IS REALLY FARKED
  • 1 month later...
  • 4 months later...
Question, In order to remove the headlights, do i have to take off the front bar? If i do, the front bar for the r33 gts-t series 1 is just 3 screws at the grille, and 2 on each side under the fender right?
  • 4 weeks later...
I dont think u need to remove your bumper to take off the headlights. The actual headlight asembly is easy to take off from the car.
But no-one has answered the question of how to take off the front plastic cover from the headlight assembly. Can it be properly re-sealed? I have cleaned my light 100's of times with that polish from Unique Auto Sports and it is just a heap of crap. It works and looks good for a day or two then bang, yellow again!
  • 2 months later...
Putting your headlights into an oven to pull them apart is going to be risky.. especially if you've never done it before. When I got my R33 series II my headlights were (and still are) frosty looking because of the crap on the inside you just can't clean.
I did manage to find a place in Blacktown called Plastifusion and all they do is headlights. Link --> Plastifusion
They will do the hole oven business thing with your headlights, polish them up (inside and out) and re-seal them again. Unfortunately for me though one of my headlights has some fine cracking. In that condition they won't pull it apart to polish it. I basically need mine replaced :D
Anyone know of a place where I can source some cheap series II headlights? Nissan want $1000+ for a pair :P
There's also a place in Keysborough, Victoria that does change overs (is it Mr. Headlight??) Do a search on headlight +replacement, I read the thread 18-24 months ago...
any link? i broke the screw that adjust the level of the headlights, now they are pointing too high. thx
Could it be these guys?
Melbourne Headlight Exchange Pty Ltd
Unit 2/ 130 Bridge Rd Keysborough VIC 3173
ph: (03) 9706 3922 Auto Parts Recyclers
I couldn't find any website link for them.
When you guys clean the headlights, are you doing it with the lights still in the car, or are you guys actually removing the headlights and then doing it? I just dont want to get toothpaste or the maguires stuff on the paint??
how you going mate?
I just got my 33 back from insurance damage of some moron reversing into it.
The second hand lights put in by "Gold Coast Panel Works" on the gold coast, looked like they were brand new. And I mean brand new when i picked it up. If you bought a new car they would stack up.
They are based on the Gold coast qld. Im not sure how they made these lights from the wreckers look like this.
They are in southport give them a buzz
I guess alot of ppl might have this problem if your line is year 94 and below.Mine's a 93 and the headlights getting a bit yellowish.Just wondering how to make it white and shiny(like big red) again.
thanks
If its just the outside(I thought it was on the inside because tried lots of different things and didnt change) MR Sheen no s**t! took it right off and thats without removing the lights
Edited by BOVed
    • Thanks for the info GTSBoy, legend. If there is no downside i'll likely just get the larger bosch units because why not... I remember hearing stories about people washing their bores with fitment of too large injectors way back when, which i guess has made me shy about it now. But happy to know it shouldn't be an issue. Ozdavroz, the little rb20 is a lot of fun- now that i have a little extra funds and time i am very glad to be tampering with the ol girl again, after so long. More RB20's on the road the better. Cheers, Rowdy
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
