Hey guyz i just wanna know where i can get my stock turbo high flowed and how much would it cost and the power difference ????
thank you!!!!
GCG do it, they charge around 2k to do a hiflow job, or 1k to rebuild a stuffed already hiflowed turbo.
i would personnaly spend the money another turbo, you can buy my rb25 highflow turbo if you want, recently rebuilt... got papers.
i want more power... :)
https://www.sau.com.au/forums/topic/103294-high-flow-turbo/#findComment-1898413
I'm getting mine highflowed on Monday :domokun:
This is from Sydneykid himself in another thread:
I can't speak about other high flows, but GCG use a brand new dual ball bearing core, new (larger diameter) shaft, new seals, new gaskets, new compressor, new turbine, machine the standard compressor and turbine covers to suite and them micro balance the whole rotating assembly. It's basically a new turbo, everything that is subject to wear is brand new. All the components are covered by Garrett new parts warranty.
It bolts back up exactly as it was when standard, everything fits, no mods, no extra parts, no missing bits, no days waiting for stuff to be made, just bolt it up up and drive away. That is simply not the case with an aftermarket turbo. You will most likely find yourself spending hundreds of dollars more buying and fabricating parts to get the off the shelf turbo to fit.
You can of course buy a turbo with a fitting kit for an RB25 (GTRS for example) but they cost ~$3,200 by the time they get here. That's a valid (total) cost comparison.
https://www.sau.com.au/forums/topic/103294-high-flow-turbo/#findComment-1898579
i want more power... ;)
how much more power would i get from that turbo compare to mine atm and would it bolt on and what price would u sell that at? thanx
https://www.sau.com.au/forums/topic/103294-high-flow-turbo/#findComment-1901402
have heard of the GCG's making 250rwkw range depends on what you ask them to do. They were also doing specials for SAU members $1800 something like that but that was a while ago.
Edited by race_snooze
https://www.sau.com.au/forums/topic/103294-high-flow-turbo/#findComment-1901716
Yes, another vote for Slide's turbos... PM him and explain what you want, he'll tailor the hi-flow to your specific needs (maximizing power, but reducing the lag). Furthermore, you'll be talking to Slide, not some salesperson who doesn't have all the answers!
All his turbos come with 1yr warranty provided you install and use them correctly. A handmade turbo that's made to spec for your own vehicle + warranty under $1k, where can you go wrong!
https://www.sau.com.au/forums/topic/103294-high-flow-turbo/#findComment-1902966
You can go wrong without ball bearings.
SAU NSW club members get 10% off at GCG.
GCG highflow = $1950
10% = $195
cost now = $1755
I'm making 255rwkw at 0.9 bar with cams on an auto.
Oh and whoever can get me an HKS 2835ProS for $1750 - I'll take 10.
https://www.sau.com.au/forums/topic/103294-high-flow-turbo/#findComment-1903138
if you're after a cheap upgrade, go with the t3 off a 300zx (the single turbo version), but these turbos are a little old so make sure its in tip top condition.
hi-flowing one of those would be more beneficial i think.
https://www.sau.com.au/forums/topic/103294-high-flow-turbo/#findComment-1904250
i cheked out this site
www.horsepowerinabox.com.au
for $3900 u can get a bolt on gt 34/40 cabable of 280rwkw or more, thats the turbo im puttin om my r33, have a look they seem to be pretty cheap turbos on here.
also another vote for slide he is cheap and very helpful
https://www.sau.com.au/forums/topic/103294-high-flow-turbo/#findComment-1905362
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
