An atmo bov will increase the backfires as its venting air to the atmo instead of back into the air intake making the afm compensate with more fuel, which means car runs richer and backfires. It used to happen on 90% of my gear changes so I got rid of the atmo bov and went back to the std one, though when I downchange at 3000rpm or more it backfires too. Need to get an SAFC to lean it out a bit.
Ive always had it, figured the aftermarket ECU caused the majority of them. Then i got an atmo BOV and its increased slightly, probably hear 6 or 7 in an hours worth of driving. Doesnt really do any harm. ALOT of turbo nissans do it with aftermarket exhausts.
But if its doing it on 90 percent of your gear changes then thats just ridiculous.
And its not strictly a backfire in my opinion.... backfires cause people to hit the pavement (see Uncle Buck).... Skylines seem to just make nice snap crackle pop noises.
Red17
yep, i believe that this 'backfiring' as described is actually 'over-run'. I think it has something to do with the fluid (exhaust) flow through a pipe and the effect of massive changes in flow velocity as you change gears (i.e very fast gas flow to much slower)... sort of a reverberation within the pipe. This happens more with aftermarket exhausts due to the increased diameter resulting in a greater flow speed differential. Of course if your mixtures are rich then this will also cause exhaust noise as the unburnt fuel is ignited outside the combustion chamber.
This is only a guess, but i think it is reasonable given the aerodynamics i studied through my (unused) mechanical engineering degree... feel free to correct me if i'm wrong.
OK...youve given me some ideas...thanks.
Some great theories, and it's intriguing that others suffer the same problem.
It is actually a popping noise, rather than a backfire, still, it is a bit distressing. Is it damaging though ??
I do have an aftermarket exhaust...a Kakimoto NS309....but the problem has only recently started....possibly after I was stuffing around with the BOV tension.
I might try tightening up the BOV (an atmo) and see if that has any effect.
cheers Ozzy
same here ED!
The Skylines are known to run very rich. Up the boost and the ECU over compensates even more. Mine is starting to sound like a rally car on the up changes ( running 0.9 bar ).
Could be wrong but I definately though it was unburnt fuel from running too rich.
BUT it sounds COOL...RIGHT???
Maybe not 90% of your driving time tho, that'd be a little annoying! I can get mine to back fire any time usually, just nail it and the back off real quick, if no back fire, lightly tap the Loud Pedal and you should hear the fruits of your labour.
I think my plugs need replacing now, but that's OK...
Yeah its just a pop, not a huge backfire... yeah its cool, there is one corner on the way home if I get the green light I can wind it down from 80km/hr to around 40km/hr and drop it into 2nd and I got a nice pop out the back... I suppose if I had a dump+front pipe and no cat I'd get flamage :P
I bet if you put the standard BOV back on you wouldn't hear a sound...
Yes the ECU expects an extra burst of air from the plumb back which is expelled from the intake system, so it compensates for this by adding fuel. This also solves the mystery of why some after market BOV make your car stall (over fuel).
A mate of mine solved this by installing an AVO atmospheric/plumb back BOV (all in one).
But if you don't mind the sound, forget about it, it's doing any harm.
Have Fun.
Yesiree, it is mine.....thanks....I think it looks good too. It came from Japan like that....I believe it is a standard factory R33 GTR bar.....Its good in several ways....you can remove the bottom lip when its been scratched to hell and repaint it off the car....(the beast has Tein's all round and is set on the stops)....it also allows you an absolute shirtload of room for a FMIC....which will come when the MRS lets me spend some more (of my) money.
cheers Ozzy
    • Ah ok. I seem to be mixing it like everyone else does so not sure what's happening. Will experiment with it more.
    • Depends on what you mean by OK. First up, was this done cold or hot? Are they reasonably consistent? Yes, they are reasonably consistent. Could be better. But unless it has had a build at some point, it is a ~30 year old engine and you'd expect some variation. Some of the difference could also be in user technique Is it good compression? Well....not numerically, no. New they were >160 psi. The one at 140 would be fine, in that context. If they were all ~140, you'd be reasonably happy. But the one that is @120 is twice as far down from the original numbers as the one @ 140. But.. (again)... technique can play a part in the absolute magnitude of these numbers, and the quality/state of repair/accuracy of the pressure gauge is not known. In the context of the above, the compression tester that was used last on my car is regularly compared to a known good pressure gauge. Not calibrated, exactly, but compared to a reference instrument that is not used for any other purpose, so cops no abuse. So we can trust the measurements off that tester. But another tester in the same workshop wasn't being compared against the standard and was reading a good 30ish psi lower. When you're reading 100 psu but the engine is really doing 130, you can make bad decisions.
    • More likely from tiny bubbles in the filler/putty. Maybe be less aggressive when mixing it. Perhaps invest in a vacuum chamber to pull the air bubbles out?** **I don't know if this is a thing for body filler. I see hardcore epoxy makers degassing their mixed resin on the regular.
    • IIRC, the speedo on these is fed from the sensor in/on the snout of the diff.
    • They were. I bought the AWD for experimenting but racing it would disqualify or disadvantage me from a few race classes. Def getting a FWD for racing.
