An atmo bov will increase the backfires as its venting air to the atmo instead of back into the air intake making the afm compensate with more fuel, which means car runs richer and backfires. It used to happen on 90% of my gear changes so I got rid of the atmo bov and went back to the std one, though when I downchange at 3000rpm or more it backfires too. Need to get an SAFC to lean it out a bit.
Ive always had it, figured the aftermarket ECU caused the majority of them. Then i got an atmo BOV and its increased slightly, probably hear 6 or 7 in an hours worth of driving. Doesnt really do any harm. ALOT of turbo nissans do it with aftermarket exhausts.
But if its doing it on 90 percent of your gear changes then thats just ridiculous.
And its not strictly a backfire in my opinion.... backfires cause people to hit the pavement (see Uncle Buck).... Skylines seem to just make nice snap crackle pop noises.
Red17
yep, i believe that this 'backfiring' as described is actually 'over-run'. I think it has something to do with the fluid (exhaust) flow through a pipe and the effect of massive changes in flow velocity as you change gears (i.e very fast gas flow to much slower)... sort of a reverberation within the pipe. This happens more with aftermarket exhausts due to the increased diameter resulting in a greater flow speed differential. Of course if your mixtures are rich then this will also cause exhaust noise as the unburnt fuel is ignited outside the combustion chamber.
This is only a guess, but i think it is reasonable given the aerodynamics i studied through my (unused) mechanical engineering degree... feel free to correct me if i'm wrong.
OK...youve given me some ideas...thanks.
Some great theories, and it's intriguing that others suffer the same problem.
It is actually a popping noise, rather than a backfire, still, it is a bit distressing. Is it damaging though ??
I do have an aftermarket exhaust...a Kakimoto NS309....but the problem has only recently started....possibly after I was stuffing around with the BOV tension.
I might try tightening up the BOV (an atmo) and see if that has any effect.
cheers Ozzy
same here ED!
The Skylines are known to run very rich. Up the boost and the ECU over compensates even more. Mine is starting to sound like a rally car on the up changes ( running 0.9 bar ).
Could be wrong but I definately though it was unburnt fuel from running too rich.
BUT it sounds COOL...RIGHT???
Maybe not 90% of your driving time tho, that'd be a little annoying! I can get mine to back fire any time usually, just nail it and the back off real quick, if no back fire, lightly tap the Loud Pedal and you should hear the fruits of your labour.
I think my plugs need replacing now, but that's OK...
Yeah its just a pop, not a huge backfire... yeah its cool, there is one corner on the way home if I get the green light I can wind it down from 80km/hr to around 40km/hr and drop it into 2nd and I got a nice pop out the back... I suppose if I had a dump+front pipe and no cat I'd get flamage :P
I bet if you put the standard BOV back on you wouldn't hear a sound...
Yes the ECU expects an extra burst of air from the plumb back which is expelled from the intake system, so it compensates for this by adding fuel. This also solves the mystery of why some after market BOV make your car stall (over fuel).
A mate of mine solved this by installing an AVO atmospheric/plumb back BOV (all in one).
But if you don't mind the sound, forget about it, it's doing any harm.
Have Fun.
Yesiree, it is mine.....thanks....I think it looks good too. It came from Japan like that....I believe it is a standard factory R33 GTR bar.....Its good in several ways....you can remove the bottom lip when its been scratched to hell and repaint it off the car....(the beast has Tein's all round and is set on the stops)....it also allows you an absolute shirtload of room for a FMIC....which will come when the MRS lets me spend some more (of my) money.
cheers Ozzy
    • Lol a few are like that with no intention of being reborn unfortunately.
    • Done, I'll do mine soon too - whenver I take out the car next. I can cheat and make it quieter by turning off VCT at idle too - but I lose the braps
    • All trim back in wired running driving. Few things to follow up on but not far off the return to the road. att.6HN4wP38LTIOISkhA8eACoBFqzfgQMahZPLA8ut0pqE.mp4 att.w2q0ux2PGuqgQTj2Os13cNHQtqcSEcCAhD_CAXy_IQM.mp4
    • The trouble with phone apps is that they really do not know the sensitivity of the mic on each specific phone, whether there is some sort of cover or skin that can change that, etc etc. So the readings off them are not calibrated. You certainly couldn't be sure that you were even within 3 dB. I have the same app on two (actually more than that) different phones/tablets and the readings in the same room at the same time are never the same. I don't mind the apps - they are as useful as a dyno - if you're testing for delta from thing1 to thing2. But not to try to generate some sort of absolute value.
    • I'm gonna use the "Sound Meter" app from the Google Play Store and as close as I can bother to these procedures: 4. TEST METHOD FOR ALL VEHICLES EXCEPT PRE ADR83 IN-SERVICE GOODS VEHICLES AND OMNIBUSES 4.1 Microphone position 4.1.1 The microphone shall be directed towards the orifice of the exhaust outlet and shall be supported by a tripod or similar device not providing excessive acoustic reflection. The general requirements for positioning microphones are shown in the Appendix. 4.1.2 The nominal axis of maximum sensitivity of the microphone shall be substantially parallel to the test site surface and shall make an angle of 45 degrees ±10 degrees with the principal direction of gas flow from the exhaust. 4.1.3 In selecting the 45 degree alignment from the outlet of a motor vehicle fitted with two or more outlets, only the angle resulting in the microphone being farthest from any other outlet must be used. National Stationary Exhaust Noise Test Procedures for In-Service Motor Vehicles Page 3 4.1.4 The height of the microphone above the test site surface shall be equal to that of the orifice of the exhaust outlet ±25mm but shall not be less than 200mm above the test site surface. 4.1.5 The distance of the microphone from the exhaust outlet orifice shall be 500mm±25mm. 4.1.6 [Relates to vertical exhaust outlets] 4.1.7 For vehicles fitted with one exhaust outlet the microphone shall be placed so that the greatest possible distance is achieved between it and the vehicle. 4.1.8 [Relates to multi exhaust outlets] 4.1.9 [Relates to multi exhaust outlets] TLDR: 200mm off ground 45 degree angle relative to exhaust flow 500mm from tailpipe exit. (I probably won't use a tripod) Here's a photo, cause I read the instructions wrong myself.
