Basicly a cam manufacturer (im in the UK) are planning to re-grind my cams to a different spec, and rather than just use bigger shims as they thought would cause too much mechanical drag (or something!) they wanted to add something to the bottom of the buckets as well.
Must admit im not 100% what he meant as i was trying to hear him in a busy office.
If this dont make sence to anyone i may need to ring him back and get a more detailed explanation!
Sounds like they want to make more $$ out of you for custom work. AFAIC the 'drag' will be more or less the same, but lift rates will change placing extra load on the springs. Don't understand why you would bother adding extra to the bottom of the buckets when increasing shim thickness has the same effect.
For an R32 GTR, valve stem diameter is 6mm for inlet and 7mm for ex., but there is a small tolerance, off course. I have some spare shims so will check diam for you.
The shims are 12.3mm diameter. The exhaust valve is nominal 7mm on the stem but is reduced down to 6mm from just below the collet area to the tip of the valve, so the caps and collets are the same on inlet and exhaust. It's around 1.9mm from the top of the collets to the tip of the valve.
Depending on the thickness of shim and bucket you require you could run a toyota solid bucket, as fitted to the late 2jz and 1zz engines. You can buy them in increments, I dont have the minimum or maximum thickness here though. They are the same diameter as a 26 bucket and you dont have to worry about shims at all. They are a little fiddly to set but once they are done you dont have to worry about them any more.
SteveL- No, as they doing it all for free :P
There was a reason, but it was when they thought the shim was above the buckets, soon as realised the cam dont operate directly onto the shim it didnt matter.
Dont think it was drag, cant remember the exact reason, but either way its irrelivant when the shim is below the buckets.
Cheers for the measurments, just happened i got them off another source this morining actually anyhow, but thanks all the same :P
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
