CLOSING DATE OF PRE-ORDER: WED 8 FEB 06
TO ARRIVE: ABT 8 WEEKS AFTER THE PRE-ORDER CLOSED
DEPOSIT PER SET = 25% OF THE TOTAL VALUE OF THE ITEM
DELIVERY: FREE FOR ALL CUSCO PARTS
PAYMENT METHOD: DIRECT DEPOSIT TO THE A/C BELOW
OUR PREVIOUS CUSCO SHIPMENT
CUSCO LIST
____________
PLEASE VISIT -> http://www.cusco.co.jp/english/e_cont.html <- FOR CUSCO PARTS DESCRIPTION IN ENGLISH LANGUAGE
THE LIST BELOW IS NOT EXHAUSTIVE! PLEASE ASK ME IF YOU NEED A SPECIFIC PARTS
SUSPENSION
COMP-S $1930 DELIVERED (180SX, S13, S14 S15)
ZERO-1 $2175 DELIVERED (180SX, S13, S14 S15)
ZERO-2 $2600 DELIVERED (S14 S15)
ZERO-2E $2600 DELIVERED (180SX, S13, S14 S15)
ZERO-2R $2930 DELIVERED (180SX, S13, S14 S15)
COMP-S $1695 DELIVERED (HCR32, ECR33)
ZERO-1 $2290 DELIVERED (R32, R33, R34)
ZERO-2 $1930 DELIVERED (R32, R33, R34)
COMP S $1495 DELIVERED (HONDA EG EK DC2)
ZERO-1 $1840 DELIVERED (HONDA EG EK DC2)
ZERO-2 $2195 DELIVERED (HONDA EG EK DC2)
WAGON VACANZA $1450 DELIVERED (HONDA JAZZ)
Cusco suspension are a little more expensive than other brand but there is a reason for it. It is becos their dampers are so tough. Coilover sets usually wear out pretty fast, but these ones REALLY last.
I have heard some sets that have gone through near 60k km and use for drifting, racing and all sort of abuse are surprisingly still damping.
COMP S - Recommended for those looking for:
- A reasonably priced adjustable suspension unit.
- A lower ride height without sacrificing comfort.
- User friendly, factory pre-tuned worry free set up.
- His first adjustable suspension kit.
- More than a lowered spring.
ZERO 1 - Recommended for drivers who:
- Has experienced the front slipping on bumpy turn-ins.
- Prefer your own setting for a reasonable price.
- Want lower ride height without loss in suspension stroke.
- Want to advance to adjustable rate units for a reasonable price.
ZERO 2 - Recommended for drivers who:
- Want to lower the ride height without sacrificing the stroke length.
- Want to enjoy various settings on road or track or weather conditions by adjusting the ride height, spring rate and pre-load settings to his heart's content.
- Want to try various tires from the production supplied to the S tires.
- Want to take the family or girl friend along on weekdays comfortably, but wants to challenge that pass or track on weekends.
ZERO-2R is the top class equipment with
- Lower unladen weight and higher rigidity made possible by the inverted shocks used on many cars competing in the World Rally
- Championship and All Japan GT Championship.
- Low friction allows a stable ride at any speed.
- A ride comfort not realised in previous inverted type shock absorbers.
- Oil circulation system allows a surprisingly low friction. Shock absorber perform at maximum from walking speeds.
SWAY BARS
FRONT SWAY BAR - $390 DELIVERED (S13, RS13, S14, S15, GTR32, GTR33)
REAR SWAY BAR - $300 DELIVERED (S13, RS13, S14, S15, GTR32, GTR33)
REAR SWAY BAR - $249 DELIVERED (HONDA EK9)
REAR SWAY BAR - $335 DELIVERED (HONDA DB8, DC2)
FRONT SWAY BAR – $335 DELIVERED (HONDA DC5)
REAR SWAY BAR – $335 DELIVERED (HONDA DC5)
FRONT SWAY BAR – $370 DELIVERED (HONDA S2000)
REAR SWAY BAR – $370 DELIVERED (HONDA S2000)
ADJUSTABLE PILLOW BALL TENSION RODS
AE86 - $769 DELIVERED
ALL OTHER NISSAN CARS - $469 DELIVERED
C33
A31
RS13, RPS13, S13, PS13, S14, S15
HCR32, R32, R33, R34
BNR32, BCNR33
Z32, WGC34, WGNC34
Y32
TENSION ROD BAR (ADJUSTABLE)
S13, RS13, RPS13, PS13, S14, S15
CA31, A31, R32, HNR32, R33, R34
BNR32, BCNR33, WGC34(2WD)
- ALL $149 DELIVERED -
FRONT NEGATIVE CAMBER UPPER ARMS
HP10, HCR32, R32GTS4, R33, R34, CPV35, BNR32, BCNR33, BNR34 - $469 DELIVERED
Z32, Z33, WGNC34 - $469 DELIVERED
HONDA EF3/7/8/9 - $660 DELIVERED
ADJUSTABLE REAR UPPER ARMS
C33, A31, RS13, RPS13, S13, PS13, HCR32 - $489 DELIVERED
S14, S15, R33, R34, BNR32, BCNR33, BNR34, WGNC34, WGC34 - $525 DELIVERED
HONDA EG6, EK4, EK9, DC2 - $544 DELIVERED
DRAG ROD (REPLACES HICAS SYSTEM)
S14, S15, R33, R34, BCNR33, BCNR34 - $459 DELIVERED
ADJUSTABLE REAR TOE CONTROL ROD
A31, RS13, RPS13, S13, PS13, S14, S15 - $445 DELIVERED
HCR32, WGNC34, WGC34 - $445 DELIVERED
PILLOW BALL UPPER MOUNT
MANY MODELS AVAILABLE - $370 DELIVERED
* NOT ALL CAR HAS ADJUSTABLE UPPER MOUNT, PLS CHECK WITH ME
CUSCO LSD
S13 (SR20, R200) Type RS 2 way - 1465 delivered
S13 (SR20, R200) Type MZ 2 way- 1295 delivered
CLUTCHES AND FLYWHEELS
S13 COPPER SINGLE PLATE CLUTCH DISC ONLY (NOT CLUTCH SYSTEM) - $450 DELIVERED
UPPER FRONT AND REAR STRUT BRACES
PLEASE CHECK HERE FOR THE MODEL http://www.cusco.co.jp/english/e_cont.html
TYPE ST - $210 DELIVERED
TYPE AS - $210 DELIVERED
TYPE OS - $249 DELIVERED
TYPE ALCOS - $285 DELIVERED
TYPE 40D - $249 DELIVERED
TYPE 40 - $249 DELIVERED
TYPE ALC40 - $335 DELIVERED
TYPE CB - $335 DELIVERED
TYPE TITANIUM - PLS ASK
* NOT ALL TYPES AVAILABLE FOR ALL CAR, PLS ASK IF YOU ARE IN DOUBT
TYPE-OST EXTRA REAR BRACE (TO BE ADDED TO YOUR EXISTING THE TYPE 40D, CB, OS, AS)
S13, RS13, RPS13, PS13, BNR32 (NONE FOR S14, S15)
LOWER ARM BAR – NOT AVAILABLE FOR NISSAN SILVIA OR SKYLINE –
LOWER TIE BAR V1 - $149 DELIVERED
LOWER TIE BAR V2 (AVAILABLE ONLY TO SOME CAR) - $249 DELIVERED
BRAKE CYLINDER STOPPER (A MUST-MUST ITEM FOR ALL CAR!!)
RS13, RPS13, S13, PS13, S14, S15 - $119 DELIVERED
CA31 - $149 DELIVERED
HP10 - $119 DELIVERED
H31 - $119 DELIVERED
BNR32, HCR32, HNR32 - $149 DELIVERED
ECR33, R34 - $149 DELIVERED
BCNR33, BNR34 - $119 DELIVERED
Z32 - $119 DELIVERED
HONDA EK - $149 DELIVERED
HONDA EG - $119 DELIVERED
HONDA DEL SOL - $119 DELIVERED
HONDA S2000 - $119 DELIVERED
SIDE PILLAR REINFORCEMENT BAR
RS13, RPS13, 180SX
S14, S15
BCNR33
EG6, EG9, EK9
DC5, S2000
FC3S RX7
ALL $340 (LEFT AND RIGHT SIDE) DELIVERED
ROLL CAGES - SAFETY 21
4 POINT - $630 DELIVERED, SAME PRICE FOR ALL CARS
5 POINT - $750 DELIVERED, SAME PRICE FOR ALL CARS
6 POINT - $959 DELIVERED, SAME PRICE FOR ALL CARS
CUSCO OIL CATCH CAN
WITH 9MM HOSE - $169.95 DELIVERED
WITH 15MM HOSE - $169.95 DELIVERED
