Hey guys i was thinking of getting a bigger intercooler for my car.
i have a r33 gtst skyline and was wonderign if you know where i can get a cheap intercooler kit which u can install yourself.
Also would it be easy to install a turbo timer and a boost controller or should i get a pro to do it for me. Anything would be helpful
https://www.sau.com.au/forums/topic/103390-intercoolers/
If u want really cheap and easy to do, go for an R34 GTT stock cooler. Its a side mount and bolts right up. Unless ur going for massive power in the long term, thats what I'd suggest. I sold mine to Konrad and he got a 25 rwkw increase running 12psi.
https://www.sau.com.au/forums/topic/103390-intercoolers/#findComment-1900137
My ears are burning :) That was 10psi choy, not 12. Can post pre and post dynos if anyones interested.
And yeah, for a cheap upgrade you cant beat it. I did the maths and its 61% bigger than the r33 one. Bolts in like it was made for the 33, installed mine the afternoon i got it off choy in 30 minutes, you dont even need to take the front bar off. For defect avoidance it looks 100% stock too- cos it IS stock :) Plus you minimise lag since it uses stock piping and really is quite a small core compared to your hybrid styles for example.
Should be good for up to 200rwkw or so i'm told.
Go the GTT cooler B)
https://www.sau.com.au/forums/topic/103390-intercoolers/#findComment-1900171
Sorry.  Imagine what it would do at 12psi then :)
Might be able to get it up to 180rwkw i imagine. For reliability i decided to leave it at 10psi for now (specially with how hot it is atm) but next time its on the dyno might as well crank it to 12psi to see what it could run.
https://www.sau.com.au/forums/topic/103390-intercoolers/#findComment-1900185
So are you saying the R34 GTT standard intercooler bolts stright in with no hassels into where the standard R33 (in front of the front left wheel) is a stright fit??? With no stuffing around????????
Sound interesting im jsut puzzel how it would with no hassle if its %61 bigger.
Thanks Michael
https://www.sau.com.au/forums/topic/103390-intercoolers/#findComment-1900257
Thanks Michael
standard r33 IC is 185mm(H) x 205(W)x60(D). That works out to be 2275.5cm3
34 core - 225mm(h)x205mm(w)x80mm(t) = 3690cm3
% difference = 2275 / 3690 x 100 = 61%
Heres a pic to show the size difference (taken by someone else not me)
Width is the same, its just a bit taller and is 2cm thicker. 100% bolts in everything fits like its supposed to be there - cheapest upgrade you can get.
https://www.sau.com.au/forums/topic/103390-intercoolers/#findComment-1900274
Well as per the countless threads on intercoolers, if ur after more than 200rwkw, go for a front mount, otherwise the side mount will suit ya. You will also need to take into consideration slight increase in lag that FMIC's give ya but again, it depends on what ur goals and other mods are.
https://www.sau.com.au/forums/topic/103390-intercoolers/#findComment-1900881
Running the standard turbo I can't see much point in going FMIC. Maybe if you are a trackwarrior - using the FMIC to keep the inlet temps down.
The standard turbo shouldnt be pushed much above 10psi - at this level the R34 cooler isn't too shabby. I had a powerfc tune and am quite happy.
https://www.sau.com.au/forums/topic/103390-intercoolers/#findComment-1901107
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
