Thanks guys,
it was my very first pass aswell, felt like the car had more in it, as i hit rev limiter in 2 gears. but andra didnt let me race again :) but i am still very happy
All the hard work with this car was done by Ant Scali and Danny Smith. i was the lucky one who ended up with the car. These two did an awsome job, built and tuned the car from the ground up in ants backyard. all the credit goes to them.
times where
10.85 @ 128mph
1.74 60'
Edited by B0BB0
I thought I put a post in here, I guess not :angry:
Congrats on your run, but a couple of questions I hope you don't mind answering. How come andra didn't let you do more runs?? And how much did you pay for this gtr? :(
i cant run anymore because cars quicker than 10.99 require alot of safety gear,
mainly a halfcage (the jap ones dont meet the standards set by andra)
ballistic blanket
external power shut off
and just some other small stuff.
cost of the car, i would rather not let out :D
Good one Bobbo , Danny was too soft on it :D
Ya gotta stop buying the GTR's I bring in , that's 2 you have owned now.
When ya gonna buy Mickos or sharons and make it a 3 some ??
Or even better , buy my current one. One for track and one for drag then ?? :(:D
hehe
Cheers
Ken
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
