i seem to have a clicking noise coming from the clutch just after i start the car
i push the pedal a tiny bit till almost take up point and it seems to stop
a little worried but im not sure if its anything major or just the cable needs adjusting
anyone know the prob?
https://www.sau.com.au/forums/topic/10341-clicking-noise/
I have this noise lasts for about 6 seconds after you start car. My mechanics have said nothing about it and people seem to think it may have something to do with auto aerial. My car is automatic so it doesnt have a clutch but i still get this noise ive had it sinc ei bought the car 6 months ago - its done nothing to the performance or wellbeing of car.
https://www.sau.com.au/forums/topic/10341-clicking-noise/#findComment-167554
nah had a bit of probs with the aircon lately so im guessing its more likely to be that - if it was outside under the engine i wouldnt imagine it would be so clear to hear. Definately more just behind the dash sound
https://www.sau.com.au/forums/topic/10341-clicking-noise/#findComment-169612
it's just cigarret side black box which controls the Drirection of the wind... with aircon.
I dont know what exactly it does... but it makes clicking nosise when you start up the car and when you change the MODE wind directions etc..etc.
if you can stand the noise then fine... but it does no harm to the car!
cheers
Joe
https://www.sau.com.au/forums/topic/10341-clicking-noise/#findComment-172394
i got the exact same prob with mine.....!!
i got it checked out by advan and its the clutch bearing.
Doesnt affect performance but makes your car sound a bit rough.
Mine makes a hissing noise when the clutch is in too.
It would cost a a fair bit in labour to fix it cause you gotta get to the clutch so i never get around to doing it.....
chow....Simon
https://www.sau.com.au/forums/topic/10341-clicking-noise/#findComment-177153
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
