you can relocate the afm to after the turbo without any side affects however i dont think you move the map sensor in front of the turbo, any confirm??
the pin feature whilst helpful is basically a kill switch it sounds like
https://www.sau.com.au/forums/topic/103414-power-fc/page/3/#findComment-1910831
  • Replies 43
Posted Images
The only side affect would be that oil that comes from your turbo (All turbos leak some oil into the intake) will coat the MAF wire and will make it dirty pretty quick. Just make sure you clean it more often.
https://www.sau.com.au/forums/topic/103414-power-fc/page/3/#findComment-1911474
You are correct in saying that the AFM can be fitted after the turbo, as i have seen it done on many VL's.
You may have misinterpruted my point ealier when discussing MAF and MAP, i was NOT suggesting the MAF readings are inaccurate because they are fitted b4 the turbo. Just stating that once desired pressure is reached, the flow and amount of air, AT A PARTICULAR RPM, would be constant.
Forgot to mention earlier: You made a point that air temp is measured by the MAF sensor. MAP ecu's also measure intake air temps, as they have a sensor fitted just b4 the throttle body.
Why would you bother to move a vaccum/boost line before the turbo? :D
Unlike an alarm, the PIN as un-bypassable :P. If you forget the PIN only AEM can reset it by "flashing" the software, in the wolf ecu. So it is ALOT more secure/effective then a simple kill switch or an immolilzer B).
If someone is really keen, they must replace the ecu, refit the AFM and tune the new ecu to my mods, or simply tow it on the back of a truck. :lol:
https://www.sau.com.au/forums/topic/103414-power-fc/page/3/#findComment-1913109
i woudnt want to, was just curious if it was valid or not
people can move the afm after the turbo so it takes away the "restriction" concept, ie: plug a q45 in the intake piping so the turbo is opened mouth for those that insist an afm is a restriction
https://www.sau.com.au/forums/topic/103414-power-fc/page/3/#findComment-1913123
    • Hi All Does anyone know what size bolts are used to mount the bonnet hinge to the bonnet on an R32 GTR please? I'd usually just buy them OEM but they are nearly £20 each and I need all 4
    • interestingly enough, i found out the answer is yes. doing a flush did fix my recurring A/T light. it might have been because of the trans filter: but that doesn't really make sense to me. the fluid/filter was super dirty. would that increase the pressure in the lines and trigger an A/T light? does the car even have a way of detecting that? i have no idea. i've done 200+ miles after the flush and no A/T light. if my A/B solenoids went bad, i would think the light would've come on. shifts and drives way better now though...at 2k rpm instead of 2500...no hesitation and downshifts when i want it to.
    • I vote go red. Only because I hate keeping gloss black clean. Was no worries helping out either! Glad you've survived the rain outs of QLD
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
