  • Replies 40
Posted Images
This is what the one from APC looks like.
The difference is that this looks like it is meant to be there and it is apparently identical to the GREDDY manifold but takes the standard injectors (not standard throttle body).
That APC one is looks no different to a Greddy Plenum!
I'd say it is a greddy plenum!
Edited by B33st
call them
http://www.apc-racing.com/
this one is cheaper (around $700) than the greddy (around $1100) and i am told that the greddy wont take the standard injectors because of where the fuel feed is where this one will.
All i want to know is if someone has used one of them, if they have had any problems and if they have had good results.
Edited by R33NT
hi guys could you help me out i'm stuck over here in the uk freezing my arse off i've been following this thread with interest as we don't have anyone in the uk that does manifolds could someone post links up to the manufactures website cheers guys
yeah i run the plazmaman plenum on my rb25. It seems to work well, with very very quick throttle response and no lag.
I don't think i have quite that power that the other one on the dyno has..
But i've only got cooler', pod, and cat-back. :blink:
That looks exactly the same as the GREDDY as you said, can anyone confirm that it is THE SAME plenum without the name logo and the expensive price tag?
I have seen it, it isnt a GREDDY and it is not that expensive but i want to know performance.
I was told by APC several customer cars ran this plenum. I guess they could be VL's but i was hoping for a couple SAU members.
Edited by R33NT
Are you sire you cant use a std fuel rail with the Greddy? I know of one that uses a std GTR rail, adn he is only using that so he can use the injectors, so if the GTR rail fits the std manifold and the Greddy, then i say the Greddy would have no problem with the std RB25DET fuel rail
Bont Blitz make an apaptor these days so the RB25 can run a complete RB26 inlet and throttle bodies...much better option in my eyes considering the price that the std GTR goes for
Yeah they do, but it costs about the same (1000+) as the greddy manifold
The GREDDY rb25 plenum still uses the standard fuel rail.  Fitted on mine with no problems.
ahh, cool. Dunno where i got that from then.
These APC ones look pretty good for the price. If i wanted more than 300rwkw, then id consider to buy one :P
std injectors and rail fits these plenums
Which is what i said back here about std rail and injectors... we ran a std RB25DET rail on a mates car with GReddy plenum and i am running top feed RB26 injectors on mine, it just depends on which injector seat you use (there is a step down in the plenum to suit each injector)
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
