Frankly, I'm not one for believing you can "blow out" the spark because of a bit of extra boost. When the spark is fired, the combustion space is closed (has been closed since about 55 ABDC). There may be a bit of swirl caused by the upward movement of the piston, but nearing the ignition point, the piston hardly has any vertical velocity. So I can't imagine enough turbulence to actually extinguish the spark.
A poor spark is usually a sign of a poor ignition system; closing down the gap is only a band-aid fix, and masks the true problem of a weak ignition system.
That said, 42psi at idle is too much. The handbook says 2.5 bar (36 - 37 psi) at idle, 3 bar at IGN = ON (pre-start), or at idle with FPR airfeed disconnected.
Have you replaced the coil -> spark contacts? Have you cleaned all grease and dirt off the sparkplug protectors on the coils? Have you had the injectors cleaned recently?
Open the gap back to "standard" (1.1mm).
https://www.sau.com.au/forums/topic/103513-surging-3000rpm/#findComment-1903643
i havent replaced the spark plug contacts only sanded them down to be a bit smoother and flatter as they were showing pitting and burn marks,ive cleanes the spark protectors and only run injector cleaner through the petrol,im pretty sure all injectors are going as ive put a screwdriver up to them and listened and the note all sounds the same on each injector
could the blow off valve have any thing to do with the miss as it was homemade and leaked at idle
also the car seems to be running real lean could this be fuel pump not pumping enough fuel?
is there any way i can clean the injectors myself?
https://www.sau.com.au/forums/topic/103513-surging-3000rpm/#findComment-1903672
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
