Order placed - Many thanks for the responses.
Hi all,
I really need a set of Tomei Cams (Type A) to suit the RB25DET (NEO). Does anyone know where I might be able to buy these at a realsitic price. I am happy to shop O/S (Nengun etc) but would prefer to spend dollars locally.
Any and all help appreciated
Cheers
Muz
Edited by Muz
https://www.sau.com.au/forums/topic/103525-wtb-tomei-cams-r34-gtt/
http://www.hioctaneracing.com.au/To.php
I thought you already had a set of the type b muz? Or did you sell those?
https://hioctaneracing.com.au/eshop/advance...&sort=2a&page=2
$1163 Tomeir Aussie distributors.
Hi Adam,
Yeah mate after reading your posts and some limited discussion with Pete, decided to sell the "B's" (gone to Germany) and get a set of "A's".
Many thanks for your response though and great to see you are still at it. Off topic, what are your thoughts on a 2535 as a replacement for the standard turbo as opposed to GCG hiflow?
Cheers
Muz
Hey mate, missed your response and only just discovered your other thread explaining yourself.
2535 is old turbo technology. Great size turbo and it was the one I wanted before the GT-RS came out and replaced it - which then by circumstance got changed to GCG highflow - which then turned out to be a great thing.
If you can get a good price for it then it's worthwhile as you can sell your old stocker intact but if you're not trying to squeeze every last dollar out of it then either of the abovementioned turbos would be right for you.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
