hmm, not sure that was the right choice, but good luck with it.
tsk tsk ebay turbos hmm, risky risky, and under $400 is even more suss  :(
is it a bolt on turbo or what?
u gotta remember u get what you pay for in 99% of cases.
good luck anyways mate :D
Brad
cant argue but if it can get me thru for 12months i'll be happy :P yeah its a direct bolt on with t03 flange.
sounds like an airflow meter! i have the same problem!
replacement time?? or just maintenance?
If it is the airflow, you could try spraying that contact electrical cleaner stuff directly into the afm, whilst giving it some rpm to suck it through properly.
Check the voltages coming from the afm, and if you have to replace buy a z32 afm for replacement.
could be afm but could also be a knock sensor problem. had this problem on my old sr20det 180sx. it would just suddenly die down in power a lot, almost like the handbrake was on (that was what i thought the first time it happened). but it would stay this way until i turned the car off and on again. I would clean the afm, check your base ignition timing and check your ecu for any fault codes (reset it too). Just a couple of things to try before you take it to a mechanic. And just for murphys law sake check / replace your spark plugs, it would be more of a missing problem if these were at fault but u never know. I had just put in a new set of NGK plugs properly gapped and it ran like shit, put in irridiums and ran great.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
