Hi everyone,
I dont currently own a skyline but am starting to look for one .
I have decided on the r33 gts-t .
I just want to ask a few questions about this model car ,Thanks
What is the most boost that can be safely run on stock internals ?
Is there any known problems with them , for example( gearboxes , engines , etc) ?
What times could i be looking at with a stock engine with add ons like - front mount , pod filter and little things like that ?
Thanks for your help ,
Luke
The most you can safely get from stock internals is around the 250 kw mark but the standard turbo is limited to 12 or so psi which is around the 200 kw mark, thats with all the support mods.
200kw = 13s
250kw = low 13s/high 12s
if in doubt do a search!
I have done and search and came up with , the r33 gbox is good and strong , but there was those posts about all the engine problems with all the rb's . Is there many people here that still give their car a hard time on stock internals without doing any damage even when the car gets old and up around the 150 - 200 000k mark ?
    • I hope one day I can do it like you. Your engine looks great.
    • If there's nothing else I can do I'll probably do something like that Someone on the internet said that ca20s and ca18 engine blocks are the same and that you can use a ca20 engine block and put ca18det parts to make a ca20det Do you think this is possible or will it damage the engine?
    • Yeah, I did some research and found out that some things are different.
    • Makes sense, thanks! Consider me very impressed. And I very much appreciate the effort in documentating all of it. You'd be surprised, or maybe not, how many people this reaches who search for things online. Anyways, I shall continue to read all of it, understand maybe a quarter, and hope that some of it sticks if I ever end up in a situation where it's relevant
    • 'Did' work on them is more accurate ~ on the R31 Skyline forum, you can spot me as 'Solder'... I've written quite a bit about the 4R01 boxes there, and I ended up reverse-engineering the older TCU type operations, so we could fudge a custom TCU to pull off other tricks...and like all things, when you do it a lot, see the failure patterns, have to find parts etc etc, your head ends up filled with whys and wherefores... there was a reason Nissan went with these in more than 60models over 16+ years... all in all, the JR401E based design is an interesting study, as Nissan changed things over the years in a never ending battle against them lunching on themselves <grin>...by the time the RE4R01A rev.C came out (often referred to as RE4R01B), they'd more or less perfected the design...
