Hi everybody.
I've just recently purchased my R31 GTS-R
that has an RB25DET conversion.
Last night with Dr_drift and Meggala we establised it has a series 2 RB25.
ALSO... now this is the bonus part.
The ECU was just sitting on the floor behind the carpet and a few screws were missing.
So we HAD to have a look and one opened up we saw that the ECU had a nice daughter board with a chip... :eek:
A fully programmable chip that is.
Right down the the valve timing.
How cool is that. :Party:
No $1,500+ APEXI Power FC for me to tune the ECU and go fast :burnout:
https://www.sau.com.au/forums/topic/10355-my-r33-ecu-chipped/
No... this isn't the R32 chipped...
i was gonna let dr_drift play with that on mine for some ground work but there's more better things now.
It's a 33 ECU with a daughter board and on that board are several chips.
This car was a race/drfit car in Japan and has many mods.
As for markings on the chip or nothing... there are none. It's a generic sort of chip with the maps bunrt on it.
It looks like someone has done it in their bedroom sorta of thing... not something brought off a shelf that's for sure.
Maybe that's why it goes so hard
:D
series 2 RB25DET
Massive STOCK frount mount
I think it has a T04E.. them came with them stock so i'm assuming it's what on there. Hits boost about 4,000rpm.
turbo extractors... STOCK
stainless steel exhaust manifold... again Stock!
It's got coils overs all round. Cusco is what's on there (i've got spare 500 pound springs as opposed to the 250/200 that are in there now)
5 Stud converstion -- > R32 GTR brakes
shortend shifter
R32 Forged GTR Rims
Monster heavy clutch.
260 km/h IMPUL dash
of course the ECU is modded
Originally posted by INASNT
stainless steel exhaust manifold and turbo extracts r the same thing. And it cant be a massive stock fmic as the stock rb25det cooler is anything but massive or front mount! :D
There are extractors coming off the block going into the turbo.
And then off the ass end of the turbo.. the exhaust manifold is stainless steel.
so that is different is it not ?
or wan't i clear ??
And the stock front mount for a GTS-R is huge. TRUST ME. i know lot's about the R31 imports.
If you see the car i can explain it.
The GTS-R's were brought out (only 800) for the group A racing.
That's why it has lot's of good stock parts.
or wan't i clear ??
off the block to the turbo is called the exhaust manifold and from the back of the turbo is called the dump pipe!
:D
Yep!
I'll be there for sure.
it has no extra boost so i guess it's running around the 9psi mark with the big cooler and exhaust...
i'm being a bit conservative but i think i should get at least 180.
Dr_drift is more towards the 200+ though.
we shall see on the day though :P
Might even do some tuning now the ECU has been found to be chipped
R31Nizmoid - Cool, if Dr-Drift can work out how to re-map the R33 ones it'd be great. But I think the write once 84 pin chips are about $70, and the re-writables are about $250 or so !!!
Unless your ECU daughterboard got rid of the 84 pin chip all together and uses a cheaper chip - now that would be cool..
J
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
