g'day everyone,
well, my boot lid won't stay up. i've tried to look inside the boot for maybe a strut or something but i can't see anything except two thin bars.
does anyone know how i could go about fixing this? if it's a strut regas problem, where are my struts?
hellpppppppp!!  :(  :P  ;)  :)
do you have an aftermarket wing fitted?
Thanks for the replies, fellas!
>HAVE YOU CHECKED TO SEE IF THE BARS ARE BROKEN?
They don't look broken - are they meant to be tawt? are these bars meant to keep my boot lid up?
No, just the standard r32 wing...
thanks heaps guys!
The R32 doesn't have struts. The bars work like an anti-roll bar in the suspension to try and hold the boot open.
Make sure the rods are not broken (it needs to be more than "they don't appear to be broken"), and the ends are properly bolted down. If you have to, climb in the boot with a light and inspect everything.
ok, climbed into the boot and had a good look - from what I can see, the bars are definitely not broken (i traced my finger along both bars) and the ends look like they are securely fastened.
the bars look very thin though and i'm not sure how they could keep that boot up!
does anyone have any idea what i should do now? :rofl:
Well, those bars hold my boot open, and I've got the GT-R wing sitting on it. Without the wing fitted, those rods literally throw the boot open.
Similar design on 240Zs helps hold that thumping great bonnet open.
  • 1 year later...
i am having the same problem now. someone took the bars off and now i dont know how to put them back on. i played around for a bit but couldnt get it working. can anymore post up a pic of how they are connected? thanks in advance :(
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
