I lost the special socket that is needed to remove the special wheel nuts on my car (one for each wheel) What do I do? I will draw up the shape of the nut and post it, maybe someone has the same one that I could use to remove them?
Depending on the design as to what you can do to remove.
The first thing you usually do in this situation is go to supercheap get a 18mm socket, hammer it onto the locknut and undo it as per normal.
If that doesn't work, you can try anything from welding a nut on to cold chisels to try and split the nut.
The 18mm socket is the easiest...
I had the same thing happen to me just before christmas, and i needed to be able to get my wheels off cause I was going on a 1000KM round trip drive...
However because I was at work, I got my GF to take it to a wheels shop and for $35 (cost of a new set of locknuts) the guy got them off and put the new ones on... Took 10 minutes
- Crimpage
that seemed like the easiest thing to do - BUY A NEW LOCKNUT
They're all meant to be different.
You just go to the shop and buy a new set as someone said, or buy the softest piece of shit socket you can find and hammer it on.
They have numbers on them, if you still have a receipt, copy of the number or say if you got them from Bob Jane or similiar, go in there and ask them to look up the receipt for you (most Bob Janes put it on the receipt for this same situation), and you can order the same locknut.
Cheers
I was in a situation where the lock nut got totally stripped at a tyre place and couldn't be removed by the special key/nut. After trying to bash a socket piece on to it, eventually they had to get a chisel and bash a groove into the side of the lock nut, then use a hammer to slowly work it off!
    • Ha ha, that is very true!  I'm too scared to leave it in the position though, it tingles my balls seeing it like that!
    • Which one did you buy? I have always wanted a decent inspection camera but have been unable to tell whether something is cheap junk or cheap junk chunk sold at just a bigger markup
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
