the rb26 runs a pair of t28's. the rb25 singles a single gt25.
single turbo's are usually "big single" and twins are usually "small twins" so not its not a good upgrade, even with a different flange.
a hiflow of your standard rb25 turbo is perfect for the power you want to make
https://www.sau.com.au/forums/topic/103658-gtr-turbos/#findComment-1905851
I believe a GCG hi-flow is around the $2000 dollar mark? correct me if i am wrong.
Aftermarket turbos can vary alot in price depending on what you want, but you have to think that a hi-flow will bolt straight on, where as an aftermarket one might take some work. (oil lines ect)
https://www.sau.com.au/forums/topic/103658-gtr-turbos/#findComment-1906823
I was just wondering whats the size difference between Gtr 33/32 turbos and Gtst turbos..
Will it make more power than a gtst turbo.?
Im runing 190rwkw at the moment and wondering whether i can go up to 230rwkw with gtr turbos and other mods.
You sure your info is backwards? RB26 = T25's, RB25 = T28
https://www.sau.com.au/forums/topic/103658-gtr-turbos/#findComment-1907786
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
