the rb26 runs a pair of t28's. the rb25 singles a single gt25.
single turbo's are usually "big single" and twins are usually "small twins" so not its not a good upgrade, even with a different flange.
a hiflow of your standard rb25 turbo is perfect for the power you want to make
https://www.sau.com.au/forums/topic/103658-gtr-turbos/#findComment-1905851
I believe a GCG hi-flow is around the $2000 dollar mark? correct me if i am wrong.
Aftermarket turbos can vary alot in price depending on what you want, but you have to think that a hi-flow will bolt straight on, where as an aftermarket one might take some work. (oil lines ect)
https://www.sau.com.au/forums/topic/103658-gtr-turbos/#findComment-1906823
I was just wondering whats the size difference between Gtr 33/32 turbos and Gtst turbos..
Will it make more power than a gtst turbo.?
Im runing 190rwkw at the moment and wondering whether i can go up to 230rwkw with gtr turbos and other mods.
You sure your info is backwards? RB26 = T25's, RB25 = T28
https://www.sau.com.au/forums/topic/103658-gtr-turbos/#findComment-1907786
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
