heres another weird one.
my front turbo is rooted. BUT:
im filling up a catch can in 15mins of hard driving!~!!!!
i was concerd id done a ringland. when i did a compresion test it came up 160-170psi in all 6 cylinders. (hot)
it only started breathing since this turbo f**ked out.(heaps smokey)
is it posible for the presure in the exaust housing to be forced back thru the turbine oil seal????
which is non existant.
any takers?
https://www.sau.com.au/forums/topic/103666-rb26-blowby/
My guess is when the turbo let go , the engine sucked ceramic dust from the exhaust wheel and has scored your bore .
Have you done a compression test since the turbo let go ? If not do a comp test and a leakdown and then you will be able to tell for sure if its just the turbo or both engine and turbo.
https://www.sau.com.au/forums/topic/103666-rb26-blowby/#findComment-1906148
yess. it hasnt "gone" the turbine oil seal is leaking. and yes 170psi in all 6
https://www.sau.com.au/forums/topic/103666-rb26-blowby/#findComment-1906190
