Hi
Was wondering today i was driving my 32 gtr around and noticed that the "4WD" light came on the dash a mate said to check the rear altezza resevior tank and we had a look and was pretty much empty! He also said it will only run rear wheel drive if there isnt enough oil to make the pressure! Anyone know what kind of oil to fill the tank up with and also if this is my problem! Tank indicates that the oil is below minium!
https://www.sau.com.au/forums/topic/103690-altezza-resevour-tank-in-32-gtr/
Filled mine up with Nissan D matic from the local Nissan dealer. Should check to see if your torque gauge is still moving also, hopefully not the pump that's no good or a leak somewhere? If it was empty there's a good chance there is a leak though....
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
