  • Replies 130
Originally posted by JiMb0
Who sells reverse indiglow for Skylines ??? I'll be sticking away from the EL as I've been warned that they kill your eyes over long trips ....
if they start to bug u then u just turn the brightness down!!
I have used em for over a year with no problems! As for the reverse indiglo u r gonna have to wait for a longggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggg time before they will be available for a skyline!
Thats 180 dash on ebay just has the needles as el go sticks!!
**** jetspeed they told me $150 for fitting, but anyways i managed to install mine and everything is 100% now except the EL panel flexes on the teacho causing the needle to stop at about 4000RPM and get stuck until the RPM drops, so i gotta get back in there and stick it down better to stop the flexing, but anyways when i get me exhaust and boost controller im getting a dyno tune and they will check the calibration when i get that done :)
guys them pplz on that website jus contacted me, if youse can get 20 ppl together they will make ones for you each in your own custom colours with your own logos etc. AND they will do km's on the outside and miles on the inside for you... happy? :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
