Hey im looking at doing some upgrading of performance parts on my car and one of the most obvious upgrade is a higher flow fuel pump...
Was wondering if the OEM R33 GTR fuel pump would be a good upgrade for my R33 GTST? What are they rated at compared to say a 044 or something?
I was talking to my mate about it and he was saying i would need to upgrade my fuel pressure regulator as well other wise it would be a useless upgrade of the pump. Is this true or is this just drunk mates thinking they know best? <_<
https://www.sau.com.au/forums/topic/103715-r33-gtr-fuel-pump-in-gtst/
I have a gtr33 pump in my car and its a direct swap and easy to install (takes about 2 hours by yourself) without hacking / cutting wiring etc.
It flows good for around 300rwkw however your injectors will max out before that stage anyway. Once you need more fuel, ie: larger injectors you can simply go for a nismo fuel reg and crank up the rail pressure as needed.
The stock rail and injectors with a gtr33 pump should be fine for just under 230rwkw ish. I'm seeing 80% inj duty max on 193rwkw with gtr33 pump
cool thanks for that mate..
yer well as said in another post im wanting 200-220rwkw on the stock turbo so yers sound like the GTR pump is the way to go.....
Do you remember how much it was roughly?
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
