Hi everyone I really need some advice from you guys.
I have a Series 1 R33 Sedan - the one with the ugly taillights lol.
I'm in the processes of doing her up but I can't get past the lights. Anyway I want to do a conversion to Series 2 taillights.
So basically I want to rip them out and chuck in series 2 ones. Has anyone done this before?
What I need to know is, is it possible?
Thanks
PS. Below are the only two pics that I could find the 1st a series 1 (silver one) and the 2nd a series 2.
http://www.skylinesaustralia.com/photopost.../big/perpage/12
http://www.skylinesaustralia.com/photopost...door/perpage/12
the 2nd one is Impul version isn't it?
Hi no the second pic is just a Series 2 sedan.
Most people hate the back of the R33 series 1 sedan & because the series 2 sedan is so rare, most people do not know it exists.
Rarity - that's one reason why I want to do the conversion.
Jlnewton, you must have one of the only series 2 R33 sedans in brisbane. Good on you they look sweet.
Does anyone know any contacts in the spare parts industry?
I contacted about 20 places on saturday and not one of them has series 2 sedan tail lights. Over half didn't even know that there was a difference between the two series.
It's hard enough finding skyline sedan parts as it is.
Thanks
Try Justjap, they may be able to source some for you.
Thanks chaos, i'll try them in the morning!
Do you know anywhere that would possibly have them in stock? Or if it doesn't take too much time could you please give me the names of the main mobs that you know in Australia?
Thanks
i think its called Alljap aswell, there a wrecker on the northside i believe (not 100%) sure. Justjap are located in Sydney but they always over night their parts etc as i've bought a few things off them.
Also go to the buisness trader section on the forum and ask around there, they may have some or can source some aswell.
Also, the only difference I can notice with the lights is that the blinkers are in a different spot.
Would that be a problem or do you think that it would be easy to get around?
And Chris I'll let you know the end result.
Thanks
I have picked up the lights and the centre garnish today & they are in perfect condition. The car I got them off was a 1997 series 2 40th annerversary special edition and it alsol had a special edition spoiler.
Anyway the spoiler looks great but the guy won't sell it without the boot. My question is would the boot also be interchangable with my series 1 boot?
Thanks
Edited by jcsky2005
Thanks
Yup. Congrates on the find.
There are a few series 2 sedansin Bris. My new one obviously, my old one is still getting around here, and I have seen a purple one, white one, two other silver ones, a creamy/off white one and a dark blue one.
Yeah thanks.
Both lights and the garnish set me back a very reasonable $450.
Dropped in to see my cousin who is a panel beater yesterday and he reckons that they will slot right in no problems. He also quoted me $100 to prep, paint and fit the lights….I owe him one!
So that’s $550 all up. I took some pics yesterday of the back, so I will post the before and after pics when the cars done.
Jlnewton, what year is yours? And did the back/taillights of a series 1 sedan play a role in your decision twice to purchase a series 2?
The car I got them off was a 1997 40th anniversary and the rear wing and stock body kit was simply just really nice. Shame that one side of the car was in bits and pieces, scattered on the side of a highway somewhere because I really liked those skirts!
Mine is a 97 manual. The main reason for going to the series 2 is the battery has been relocated back to the front of the car, same layout as the R34s. Means a much more usable boot space which is the whole reason I wanted a sedan, to be more practical.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
