you're gonna have to tell me how you did this or where you got it from.
well i cant its a secret project me and my budy is working on for a rb20 :D:O
just kiden it was EZ i took a rb20det intake and cut it of right under the fuel. made six adapter plates for the thottle bodies and welded them on and bolted the throttle bodies on them. the throttle bodies are off of 90s toyota levin (corolla)
that is it! im building a rb20e bottom end with a rb20det head and going to run the throttle bodies open like six carbs hoping to get about 10.5 compression out of it and it will be in a cefiro
well i cant its a secret project me and my budy is working on for a rb20  :P  :P
This looks absolutely nuts^^^^
Why not use a RB30 bottom end instead of the RB20DE? You will make ooodles of power and torque from a an N/A RB30/26 and that throttle body setup!
the rb30 was not made for the japan market and if u find one it cost a lot and the rb26 is up in price too rb20de can get for free all the time
Over here in Aus you cant give them away :P . RB30 is a common motor here. They are renowned to still have hone on the inside of the bore after 400,000km/s or 250,000miles, and still perfect to rebuild or I have heard of people pushing it hard on 20yr old stock bottomends.
You could get a bare block and the bare necessities sent over to the US for fairly cheap, I reckon. Would certainly be a tough motor in a cefy and N/A too.
  • 8 months later...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
