hi mate,
i'm not sure on the SE37s, i will check it out. basically if they have a screw on type cap, and are Rays wheels, these caps will fit.
i was just thinking how much better these would look attached to wheels, as opposed to their current position on my bookshelf. lol
  • 1 month later...
Do you still have these?? I skillfully lost one of the centre caps on my Volk GTPs a couple of days ago. . . . Then I remembered this thread. I assume they would be a definate fit for the GTPs? Anywayz, are they still available?
    • Ah yeah I forget we aren't talking about an RB.
    • Fellow ADHDer to fellow ADHDer; Don't chase that paint perfection. Paint the bumpers, and put them on.  Leave the respray for another day. Plus, no one is going to see those old areas above. Any spots of surface rust, give them a clean up, prime, then hit with a white paint just to protect them from rusting. Again, no one can see it.   #Mine hasn't been on the road since 2011 cause ADHD... I've slowly learned not to keep f**king with shit if I don't need to...
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
