  • Replies 44
I think you misunderstood. I wasnt saying that autos are slow and that only pansys drive them, I was saying erics car is basically the same mods done as mine, and ive got faster times, with the only difference being the gearbox as I can launch better with the clutch and manual box.
And I wasnt having a go at anyone, just saying in comparision
Well change of plans again (feel like a yoyo) able to get a conversion kit fron the toy shop over in sydney for 2600 deliverd to xspeed.
the problem is i can decide which way to go
1. manual conversion, new clutch for 3800
or
2. power fc, shift kit, blitz spec s boost controller for 4000
need help :) will be ordering next monday!!
Edited by Pal
or
need help :O will be ordering next monday!!
you are aware the power fc doesnt work with the auto properly ? this will limit you to interceptor devices such as the safcII or emanage .
if you search the forced induction forum theres a few dozen threads on it
complete manual conversion kit sourced (from another company in adelaide)and will be paid for on monday, week and a half wait for it to come over, car goes in to workshop auto, comes out manual :lol: then goes over pits :O
then to the drags for that 13
only downside is it will cost about 800 bux more than thought
still worth it
Edited by Pal
  • 3 weeks later...
well conversion done finally, feels great. just got to get my speedo sorted out on friday and go over the pits and thats it :whoops: . cost alot more than expected (4700 with safc tune) but i think its worth it. got alot more power out of it, went from 215rwhp to 255.8rwhp.
now where is that drag strip??!! :O
Josh, SAFC2 was tuned previously also when the auto gearbox was in to give him the first figure. The only difference is the gearbox between tunes, correct me if im wrong Eric..
Miller, about the same.. 3"turbo back, pod, fmic, 10psi = 257rwhp
Eric (Pal) has same mods, but a filter element in airbox instead of pod filter
  Pal said:
settle guys, went to the pits today and its all good news exept one thing. He said they will only look at the modification done eg make sure the gearbox, peddles, clutch etc is put in properly. bugga have A&Z Blitz 17" by 8" rims -no good only allowed 7" (thanks to tyre power for telling me that)
hmmmmm my car came out factory with 8 inch rims and they are legal 16x 8 factory standard so i can legaly have 17 x 8 rims on it
the dpi says that ya can only have max 7 inch wide rims if your car came out with rims less than 7 inches wide .
if your car came out with an 8 inch wide rim you can not go any wider but u can go up in height copys my post from imports 101 site lol
Alternative road wheels
Alternative road wheels are permitted under the following conditions :
Rim width must not exceed the maximum rim width specified by the manufacturer by more than 25mm (1") (for passenger vehicles manufactured after 1st January 1973, the manufacturers rim width shall be taken as that specified on the tyre placard).
In any event, rim width shall not exceed 177.8 mm (7") unless specified by the manufacturer as standard equipment for the vehicle in question. No increase in rim width is permitted for vehicles fitted with original equipment rims in excess of 177.8 mm (7") width
ok,
i have stock turbo runnin 12psi,fmic,3"cat back stock front pipe and split pulse dumpa,k&n panel filter, safc2
had the safc tuned bafore fmic went on at 215rwhp, at a guess went to 220-225rwhp without a retune of safc. with gearbox and retune of safc went to 255.8.
as for the price of gearbox
parts come to $3000(america sucking up parts and hard to get, prices for conversion kits go through the roof)also my tailshaft cost 300 cause i have abs and they are hard to get(so ive been told).
to fit 1550(includes new extreme clutch)some machining, bits and pieces and about 10hrs labour
standard 150 for dynotune for safc2
thats about it :)
i dont think i could have got that out of mine, it just wouldnt respond to anything else. im happy with what i got now, i drive it every day and if i go for anymore power it becomes less reliable and fuel costs start going up, now it time to spend on maintenance.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
