for 90 degree corners, on the street where the limit is 60, the ratio of 2nd gear is usually right for exiting the corner. imagine putting it in 5th and trying to accelerate back up to 60 :P
after a month or so of practice, you'll probably look back at this question and just think "because".
https://www.sau.com.au/forums/topic/103788-why-2nd-gear/#findComment-1907403
its actually all about your speed when you turn. the reason y your instructor told u to turn in 2rd is becoz the 2nd gear would be more suitable for you when u come out of the corner, u are on your right gear and ready to accelerate.
if u can handle turnin a lot faster, of course u can turn in your 3rd gear but for a beginner, it is not safe to do it.
https://www.sau.com.au/forums/topic/103788-why-2nd-gear/#findComment-1907435
As long as the engine isn't labouring too low in the rev range, or screaming its tits off on the rev limiter, the choice of gear is entirely up to you. Having speciffic gears for speciffic occasions is good when you first start learning to drive as you haven't developed good gear selection judgement.
But with today's 5 and 6 speed gearboxes, there are often more than one than one ratio to suit a given occasion. On a 50km/h back street, I may choose 3rd, 4th or 5th gear depending on situation, gradient and mood. Going through corners and roundabouts I might choose 1st, 2nd or 3rd again, depending on mood, radius and situation (or 4th gear if I'm in Mum's Alfa Romeo - man that things torquey for an atmo 2 litre!).
Oo...I was under the impression if I turn on 3rd gear it'll damage the car....also I was adviced to change gear only after I exit the corner completely..is this necessary?
Won't damage the car in 3rd gear unless the engine is labouring (which you will feel and hear). Changing gear only after exiting the corner completely is about keeping your driving smooth. A mid corner gear change can be difficult to get smooth without practice.
Edited by Big Rizza
https://www.sau.com.au/forums/topic/103788-why-2nd-gear/#findComment-1908626
How to turn a perfect 90 degree corner:
- Slow down from 100km/h to about 30km/h by the time you reach the corner.
-Turm the steering wheel in the selected direction (left or right) as you push the clutch all the way in.
- Rev the engine up to 5000rpm as you enter the corner and then dump the clutch.
- As the ass slides outwards and you car overcorners, spin the wheel back in the opposite direction and slowly let of the revs letting the wheels regain traction while maintaining the car in a forwards direction.
- Check for cops.
- Stick your hand out the window and give a thumbs up to the school girls you almost cleaned up.
- Continue accelerating back up to 100km/h as you bask in glory.
https://www.sau.com.au/forums/topic/103788-why-2nd-gear/#findComment-1909122
- Check for cops.
haha love it :lol:
i mean no, bad influence!
https://www.sau.com.au/forums/topic/103788-why-2nd-gear/#findComment-1909234
your instructor wants you to go slow around corners so you dont crash. going fast around corners = pain
my cars auto and i still throw it into 2nd when im doing corners.
that's not cool, you'll stuff the gearbox doing that. it's undue stress. those auto gearboxes are designed to be driven in Drive gear. 1 and 2 (or more if you're lucky) are mainly for hills. do you see a clutch on that thing?? just a heads up
https://www.sau.com.au/forums/topic/103788-why-2nd-gear/#findComment-1909736
I guess you wouldnt call it "necessary" for driving when licensed but for a driving test yes it is. He would of also told you to make sure you have selected second gear before you start to turn.
It's to do with "vehicle control". They (testers) want you to have full control of the vehicle during a turn, meaning both hands are to be on the steering wheel during the whole of the turning manouvre i.e dont up/downshift during the turn as you will be driving with one hand for a moment.
Dont remember back to my P plate test but on the numerous heavy vehicle tests I have done it was an immediate failure to down or upshift during a turning manouvre.
https://www.sau.com.au/forums/topic/103788-why-2nd-gear/#findComment-1910551
Cornering? Piss easy. As already said & is true is that 2nd for the speeds you "should" be doing the correct speeds for that gear to be on suitable rpm. Brake in a straight line, finish your gear change before your turn, slow in fast out etc etc.........
ctjet, grow up.
https://www.sau.com.au/forums/topic/103788-why-2nd-gear/#findComment-1910561
As other people have said, it'll only damage the engine if you're so low in the rev range that you make the engine lug.
But, as a learner, you shouldn't be screaming around corners so second gear should be the "right" one for a novice.
With a bit of experience, for street use its not dangerous to change gear mid corner. If you're at the limit its not exactly smart to go changing gears (since it really messes with the balance of the car), and for a novice it might be asking you to do a few too many things at once.
Don't forget, the driving instructor is there to each people who have little to no driving experience what is the "best practice". Once you start driving, you'll find out which best practices aren't mandatory for commuting (stuff like push/pull steering, which is good to learn but almost useless in a modern passenger car).
https://www.sau.com.au/forums/topic/103788-why-2nd-gear/#findComment-1910585
thanks for the advice..so now I can turn in 3rd gear..muahhahaha
but still when exiting the corner..it's gonna be slow to accelerate if at 3rd gear~~ I'll stick with 2nd I guess...unless insanely fast
https://www.sau.com.au/forums/topic/103788-why-2nd-gear/#findComment-1911303
Your instructor told you to go around the corner in second gear because this is the 4th step in the system of vehicle control.
First is identify the hazard.
Then check your road position and adjust accordingly.
Check your mirrors.
Gears/brakes.
Indicate for the relevant hazard
After completing the driving task continue on at the speed limit/with traffic flow.
(I am doing a driving instructors course at the moment, and couldn't help)
https://www.sau.com.au/forums/topic/103788-why-2nd-gear/#findComment-1916707
  • 2 months later...
- Check for cops.
i did what he states and i got some cheers and almost a ticket from the cops :ermm:
its recommended if ur a beginner =)
https://www.sau.com.au/forums/topic/103788-why-2nd-gear/#findComment-2067842
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
