Other than the condition, I've got logbooks, and the current kays have been logged with RTA each year - also have compression test and dyno sheets.
https://www.sau.com.au/forums/topic/103808-sold/page/2/#findComment-2111805
I don't know else you could find one in this a good a condition for this price...
I'd like to sell ASAP as my new project car is already here, and I don't have room for them both.
Someone will get a bargan here.
https://www.sau.com.au/forums/topic/103808-sold/page/2/#findComment-2112307
Email sent...
Bump for a monday. Keen to sell before the 30th if I can.
Few offers received, but no one to back it up with money yet :angry:
Cheers
https://www.sau.com.au/forums/topic/103808-sold/page/2/#findComment-2116439
Bump for today.....
Remember, the car can travel :ban: Currently under offer, however no money exchange yet.
I can't freakin belelve that this wasn't snapped up ages ago.
https://www.sau.com.au/forums/topic/103808-sold/page/2/#findComment-2120468
    • Hell, I know that much. So far I just put it off as "part of the deal".
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
