If you use the wildcard * you can search for "air*", "CAI*".
Anyway, I kept the standard airbox. I removed the LH headlamp and removed the stock POS airduct from the underside, then replaced headlamp. With the hole that is left, I fitted some flexible 3" corrugated hose; it squeezes through the hole in the radiator support panel and into the triangular fitting on the airbox. The other end hangs down to just above the duct that feeds the standard IC.
yes its very hard to do on 32's on mine i cut the standard snorkel thingy that goes into the head light so i could fit some pipe down under it and it come out where the vent for SMIC is i also have a pod with a box, seems to work pretty well... you can tell the difference i reckon when you get the box put around the pod but thats off topic.
cheers simon
