morning all.
i spent some time on sunday making a cold air induction for the cressida, utilising a chaser head light so that i could have a cold air scoop but also have lighting on that side of the car. at the last SC meet i had major problems with intake temps of 72 degree cel, as my air filter sits in the only location i have room for it in my grandpa designed engine bay, so i am looking to get some cooler air into it.
upon reading my sport compact rule book it says must run complete headlight. i asked around at the last round in sydney, and i got mixed interpretations of the rule.
one frame of mind was as long as there was lighting on that side of the car it was ok.
the other was, if you dont have the glass and bulbs in all areas of the headlight that it came from the factory its not a complete headlight.
i know i spoke to paul about this and another guy in our class who had a bulb and also an air duct in the headlight, and i think if there is lighting it should be ok.
has anyone got any ideas on this rule or have they spoken to ohalleron about it?
any thoughts would be appreciated.
Shane.
https://www.sau.com.au/forums/topic/103819-srwd-rules/
well cow girls.
after a lack of banter on the topic i emailed jason ohallaren.
the complete headlight is defined as complete
ie full glass, bulb in full working order as it is from the factory. so for all point scoring rounds cars in S/RWD must have a complete functioning head light.
screws up my plans for my cold air, but i will find a way.
Shane
https://www.sau.com.au/forums/topic/103819-srwd-rules/#findComment-1918533
  1JZ.747 said:
well cow girls.
Shane
Jason is right
Rule no. SR 7.6
Complete headlight and taillight assemblies mandatory; must be operative.
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/103819-srwd-rules/#findComment-1920725
  Mik said:
Do S/RWD rules allow you to disable factory fitted power steer?
Rule SR 3.2 Must retain full, original OEM steering gear.
I have only tried disabling power steer once at the track...it was no real benefit other than giving my forearms a good workout.
https://www.sau.com.au/forums/topic/103819-srwd-rules/#findComment-1920765
  Mik said:
Who knows...but my p/steer is staying
Bit confused here, why are you worried about S/RWD rules allowing you to disable factory fitted power steer then?
you planning on stripping the car when you race, I wouldn't worry about it my 10.5 was done with a fullweight car + some due to surge tank, big single turbo etc
https://www.sau.com.au/forums/topic/103819-srwd-rules/#findComment-1921811
I'm not planning on it...if I go to the drags again, I will run in the same trim as I have always done.
* Full weight, including all trim, spare wheel, tools and jack
* Street Tyres
* Full exhaust (a quiet one at that)
* Stock Airbox
* At least 3/4 tank fuel
https://www.sau.com.au/forums/topic/103819-srwd-rules/#findComment-1921843
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
