morning all.
i spent some time on sunday making a cold air induction for the cressida, utilising a chaser head light so that i could have a cold air scoop but also have lighting on that side of the car. at the last SC meet i had major problems with intake temps of 72 degree cel, as my air filter sits in the only location i have room for it in my grandpa designed engine bay, so i am looking to get some cooler air into it.
upon reading my sport compact rule book it says must run complete headlight. i asked around at the last round in sydney, and i got mixed interpretations of the rule.
one frame of mind was as long as there was lighting on that side of the car it was ok.
the other was, if you dont have the glass and bulbs in all areas of the headlight that it came from the factory its not a complete headlight.
i know i spoke to paul about this and another guy in our class who had a bulb and also an air duct in the headlight, and i think if there is lighting it should be ok.
has anyone got any ideas on this rule or have they spoken to ohalleron about it?
any thoughts would be appreciated.
Shane.
https://www.sau.com.au/forums/topic/103819-srwd-rules/
well cow girls.
after a lack of banter on the topic i emailed jason ohallaren.
the complete headlight is defined as complete
ie full glass, bulb in full working order as it is from the factory. so for all point scoring rounds cars in S/RWD must have a complete functioning head light.
screws up my plans for my cold air, but i will find a way.
Shane
https://www.sau.com.au/forums/topic/103819-srwd-rules/#findComment-1918533
well cow girls.
Shane
Jason is right
Rule no. SR 7.6
Complete headlight and taillight assemblies mandatory; must be operative.
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/103819-srwd-rules/#findComment-1920725
Do S/RWD rules allow you to disable factory fitted power steer?
Rule SR 3.2 Must retain full, original OEM steering gear.
I have only tried disabling power steer once at the track...it was no real benefit other than giving my forearms a good workout.
https://www.sau.com.au/forums/topic/103819-srwd-rules/#findComment-1920765
Who knows...but my p/steer is staying
Bit confused here, why are you worried about S/RWD rules allowing you to disable factory fitted power steer then?
you planning on stripping the car when you race, I wouldn't worry about it my 10.5 was done with a fullweight car + some due to surge tank, big single turbo etc
https://www.sau.com.au/forums/topic/103819-srwd-rules/#findComment-1921811
I'm not planning on it...if I go to the drags again, I will run in the same trim as I have always done.
* Full weight, including all trim, spare wheel, tools and jack
* Street Tyres
* Full exhaust (a quiet one at that)
* Stock Airbox
* At least 3/4 tank fuel
https://www.sau.com.au/forums/topic/103819-srwd-rules/#findComment-1921843
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
