Rx8 Turbo Kitq
Rotormaster in Sydney has a supercharger kit for the RX8 it utilise the standard exhaust and everything but has a substantial powe rincrease.
I believe a pro Charger is used which is sourced from the states
I have had interest in hearing more about this for a long time, but there seems to be very little information on it around... So far I have only found this:
From http://www.rotormaster.com.au/subPage.asp?cid=64
"Ready to roll...The New Rotor Master RX8 "Supercharger" Kit Supercedes the Stage 1 Turbo Kit!
After much research & further development to transform the RX8 Renesis Rotary Engine's power output, the crew @ Rotor Master are estatic with the results of their recently completed Stage 2 RX8 Kit with Joe opting to sideline the Turbo for the Pro-Charger!
The first Aussie assult on an RX8, Rotor Master first introduced the Stage 1 Turbocharger kit some 12 months ago & despite the unquestionable power gain, Joe & the crew still sought to increase performance levels.
So why the switch?
The GT 28 Turbo as used in the RM8 TurboChager Kit did not generate sufficient airflow & there was excessive exhaust pressure... enter the ProCharger with zero exhaust pressure and three times more air flow - a result on par with what you would expect from a TO4 Turbo!
Sheer determination coupled with persistant hard work has now produced a better overall product resulting in a kit now capable of producing a 303 rear-wheel horsepowered RX8!
(226 rear-wheel kilowatts on just 6 psi of boost with the car still revving to ten grand)... a relishing delight!
In terms of ECU, the kit is operational using a piggyback interface unit that manipulates the factory input sensors to obtain desired output (ignition & fuel delivery) when required - it all just simply plugs into place.
Enticed Yet?
So what's in the Kit?
The Rotor Master SuperCharger Kit includes a US-made ProCharger C-2, a DNA Motorsport PowerMod piggyback ECU, Front Mount Intercooler & Mounting components. The Rotor Master Kit is a ready-to-go kit that bolts into place with no major modifiaction work required - in fact installation (drive in-drive out) requires less than one days work!
Priced at AUS $11,900 in boxed form (ready to install) the SuperCharger kit is modest value with a 200+ kW rear wheel result with a standard exhaust system ensuring noise maintained at an appropriate level.
Plans for a Stage 2 SuperCharger Kit inclusive of an aftermarket fuel pump, larger injectors, aftermarket ignition systems plus smaller pulleys for around 10-12 psi of boost are already in motion. The Stage 2 kit hypothesised at producing over 400 rear-wheel horsepower, or around 300 rear-wheel kilowatts!"
Does anyone have any extra info?
 Share
    • Hey guys any recommendations for fitment for a stock 94 GTR R32  Want to order work meister s1 3p and would like a nice looking flush fitment. Plan to get MCA coilovers to set ride height etc. Just confused on offset, brake clearance etc.  Never purchased after market wheels so I'm a bit concerned since it's a long wait to order and I don't want to order the wrong specs.
    • Update: Done: -Running on 6 cylinders, one injector was gummed up. I made an injector tapper, bit of Teflon on the end of a metal rod.  That fixed the injector. Need to replace one injector plug, the fastener is broken. -Coolant bleed -Fixed 4WD warning light, bleed 4wd system -Fixed electrical problems: alarm, brake lights, various broken plugs  -Got all the parts ready to connect head drain. Head drain is fitted with a blocker atm Todo: -Fuel pump dead, Been cleaning out the tank, had a lot of tobacco looking stuff, think its OEM foam. Got a Walbro 460 to put in. Probably going to add a relay to give the pump a solid 13volts. Replacing all the fuel hoses, in tank etc. -Front drive shafts still not back on. Waiting on parts. Would like to buy some new ones, but probably going to patch these up for now -Replacing gas struts on back door. Waiting to be returned -Headlights need a polish/repair -Going to touch up the paint a little. -Clean up the interior -Connect up heater plumbing -Cosmetic stuff, powder coat replace rusty parts, replace rusty bolts, wiper blades, silicon missing rubber -A million other things
    • Don't do this unless it never gets hot where you are.
    • Upgrade time. Been a long time coming, but I was able to get my GTR to a reputable builder in the States. List of upgrade parts below: RB30 (Sourced from Australia) PRP RB30 timing belt kit with all options Nitto pistons Nitto I beam rods Nitto oil pump King engine bearings New RB26 Head (Grabbed during Heritage run) Kelford 272 cams mild lift Supertech intake and exhaust valves over sized Nitto Head gasket Greddy Oil Pan Sump GKtech fan blade and adapter Koyo Radiator Borg Warner S362 SXE 6boost turbo manifold T4 divided  Turbosmart wastegate Pro-gate 50 lite ID1340x injectors Radium external surge tank Walbro 450 fuel pumps x2   All Parts in hand and awaiting my turn in line at the shop!
