R34 Key Transponder
Just buy a bunch of covers off aliexpress, they're like $5 each. Rattle-can them and stick them on as needed/fly off.
On R32s etc the variable resistor of the TPS is pretty much only for the auto trans CU. The switch is the idle position. Yes, later ones want to see pretty close to 0.45V to declare idle position.
TPS sensor needs to be adjusted such that idle voltage is 0.45V, then relearn the TPS if applicable. From what I recall in the R32 GTST and similar ECUs they care far, far more about the actual TPS closed switch but later models seem to only keep track of voltage.
