10,000 without wheels and stereo
FOR SALE:
Celsior Luxury package
1989
Quad Cam V8
160xxx kms
Colour - Green over Silver
MODS:
Removed air bags and installed lowered custom springs(to suit celsior)
Twin 2.5" HOTDOG Exhaust system(sounds AWesome)
High Tech Performance UNI-FILTER(pod filter)
Updgraded Brake Pads
Dark Window TINT
20" chrome Wheel with 95% tread ($4000)
Camber adjustment
STEREO:
Latest model Pioneer touch screen dvd player
Custom made facure place(where head-unit sits)
4x4" high end(top of the range) HERTz Competition spleakers
2x12" POLK MOMO subs in custom box with custom ports (also a custom port into the cabin as well)
JVC 4 channel amp
Audioson full competition amp(to run subs)
I have recently replaced all 4 rotors and pads and just had all the seals replaced in the gearbox(Lexus also inspected it and said it is basically brand new) This car is in fantastic condition and has been looked after constantly. The car has been hardly driven and will be hard to let go. IT comes with Rego until MAY '06
The stereo alone is worth 5K++
The pics i have got a pretty crap, (crap camera and angles) but let me know if you want more.
$16,500 neg. (depending on stereo)
Call Georgie on 0422 802 168 or [email protected]
Edited by ITA-Drifta
https://www.sau.com.au/forums/topic/103851-vip-stlye-celsiorls400/
  • 1 month later...
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
