Hey guys have finished the first stage of the engine Bay tidy up!
Have post some before and after pics
Have finished tidying up the exterior of my Purple R33 GTR and now to the engine bay!
The car was only recently imported and the *lovely* previous japanese owner spent thousands on quality upgrades for this GTR and then had the bright idea of painting the rocker covers baby blue :D
I throw it out there to my fellow skyline enthusiasts of some options I have to make it look better than what it is now (isnt going to be hard)
Here are some of my thoughts
(1) paint rocker covers same colour of car (purple) or R34 red or a grey hammertone look as I saw on the white Mines R34 GTR?
(2) polish the plenum and other bit that has "twin turbo" written on it
I don't want a show car just want the thing to look a little better than baby blue which looks like it has been applied with a spray can :unsure:
Any comments or photos of other engine bays that look hot will be appreciated, or if anyone knows of any good metal polishers can they let me know.
Cheers
*sits back and waits for the flood of brilliant ideas*
Edited by TOY 33
https://www.sau.com.au/forums/topic/103867-r33-gtr-engine-bay-options/
Melv - There's a few nismo goodies under there good for about 300kw at the paws ;) Purple was my first thought however the Mines R34 GTR rocker cover paint job is growing on me. Have a look in HPI, I think its the most recent one with the new GTR on the cover.
Mushroom - Hot!
Did you polish yourself ;) or did you get some one to sweat for you? ;) What aftermarket plenum do you have? Might have to pop around for a look for ideas ;)
Col - Had exactly the same car as you previous to the GTR :) great car and even though it had half the power, I still miss the driving sideways at every possible opportunity :) Can't beat a 500hp GTR but!! (maybe a 600hp GTR or 700hp or 800hp......*starting to drool and wallet is having heart attack*)
Thanks guys keep the ideas comin B)
this is wat we are doing to mine at the moment
1. i made a custom wiring harness (to hide all wiring, relays and fuses)
2. engine covers in carbon fibre
3. all hoses/lines replaced with braided ones
4. every nut, bolt, washer, bracket etc chromed
basically i took wat we did with this S2000 and did the same to my engine bay
i dont know how far u wanna strip ur engine bay
but if u neaten up all your hoses and wires
paint ur engine covers same colour as your car
polish ur intake plenum, other piping and strut brace
throw in some braided lines
get a nice partition for your air filters and polish it
i could go on forever but it all depends on how far u wanna take it
I use a greddy plenum just haven't put the sticker back in yet :D
yeah I have polished some myself, other bits professionally.
you are more than welcome to come round and have a look
0432453045
Get the full NISMO piping kit, polish the rocker covers, get the HKS Kansia carbon spark plug and timing belt cover, the GREX oil filter moval kit, PWR Radiator, Blue silicone pipes everywhere, carbon box for pods, polish the plenum, and carbon Garage Defend air guide. . . . . . . .
You know you want to. . . . I can live out my dream through someone else then :P
Decisions, Decisions Decisions !!!!!!! Thanx Guys for some great ideas
2Gu up - How much patience do you have :( your engine bay looks unreal, however I'm not looking for a show bay as yours is just a tidy up. Think I will do things along the lines of what you said to do :)
Mushroom - What person did you get your plenum polished at and was he local? Might give you a call next time i'm in Brissy thanx for the offer. I think you also got out-blinged by 2Gu up :lol: :lol:
M&M - ARGGGGH ! Yours looks unreal! That is exactly what I am after! What colour is your covers painted in? Decisions Decisions! Congrats on a neat engine bay, pity your in Vic unless I'd come around have have a look.
Jas - Says he who has money now :P Good to hear you still pine for the GTR :D Withdrawal symptoms suck. Just go sit in the corner of a dark room and gently rock back a forward muttering GTR, Twin Turbo, 2.6, 4wd..... :(:):)
So far I'm thinking
Covers purple
Polish plenum and intake bit
tdy up wiring and stuff and may be some aftermarket lines and hoses
Keep the ideas coming as the end of the week decisions have to be made and it will be the time for action!
Cheers guys :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
