Ok so i have a RB20 and wanting to run over 300rwhp with 20psi
I was stuffing around with coilpacks for ages trying to fix a miss but eventually gave up and have upgraded to a falcon coil pack.
But the miss is still there, even with a 0.55mm gap it still misses a fair bit under boost. When the boost is turned up to 18/20psi it misses of virtually all cylnders.
I have a Power FC and my tuner played around with the coils settings with datalogit but to no avail. I have changed coils/plugs/ignitors etc etc many times and none make a difference
I got my hands on a hand controller a few weeks ago and as the revs got towards the top end (when it starts to miss) the volts dropped on the hand controller read out (14.4 down to 13.2). My friend has a very similar setup to mine so i did the same on his and it stayed a constant 14.4v through the rev range.
So i changed the alternator to see if it was the problem, once again with no luck. Now im going to change the alternator belt as i have been advised that it may be slipping with revs but if this does not work im as a loss of what to do.
does anyone have any ideas about what could be my problem?!?
any help would be appriciated
thanks simon
Edited by Cerbera
https://www.sau.com.au/forums/topic/103874-unfixable-miss/
14.4 is a little high for a warmed up motor.
Generally 14+ is acceptable for a cold motor however once the motor has warmed it will drop to approx 13.8v.
Mine under full load at high rpm will drop to ~13.3v.
I don't have any issues with coils breaking down.
But.. I'm not running any where near as much boost as you.
What plugs are you running?
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1910411
for you to be drawing some nuch current in the electrical system to drop the voltage like this you must a serious issue in the electrical system(it may not even be related directly to the ignition system but is related to rpm).
It might be worth checking the supply wiring to the ignition system poor conducts can brake down under load but still supply an electrical path when not stressed, plus the voltage you reading on pfc make be quiet different to the volt the ignition system is recieving
CHECK THE WIRING LOOM(as it could be a simple as bad supply wire)
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1911300
My suggestion is to do a leak dow test to eliminate rings, pistons and valves as the cause. In the old RB20DET we were running 225rwkw (302 rwhp) at 19 psi on standard coils and copper NGK's at 0.8mm. So you are not looking at anything extraordinary.
:ban: cheers :)
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1911626
ok to answer some questions...
i run bcp6es and bcp6e and they both are the same, might get my hand on a set of bcp7es and try them?!?
base timing is around 15 deg and the timing is a few degrees off pinging top end like a good proper tuner should do (around 13-15) :P
we did put more timing in on dyno but it just caused pinging and knock count was getting on the high side of just under 60
the power running to the ignitor was checked at idle but not under load... may have a check of this again under load
the rings/pistons and valves are assumed to be fine as there is virtually 0 blowbye from the engine plus the fact that the miss goes away if the plugs are gapped low enough...
plugs come out with all normal markings of a good working engine, maybe a tad rich but thats for saftey
grim32, i may give this a try. i shall talk to my tuner, datalogit is used to adjust correct?!?
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1913222
While it may not directly help your issue, make sure you check the real simple things.
I had a similar miss, only showed up under high boost. We replaced ignitors, coil packs, spark plugs so many times it wasnt funny. 4 months later we had it on the dyno (because I had been too lazy to get it properly checked) to try and solve the problem when my mechanic noticed under large boost, an injector o-ring was being pushed up slightly... enough to cause a leak and cause the miss.
An $0.80 part caused 4 months of pulling things on and off of heartache.
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1913294
That caused some serious hair pulling. If you have the car on the dyno have a good listen around the intake manifold, Nik's car made the slightest little whistle and it was only #6 injector that was leaking but caused a really bad miss. It's well worth a look.
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1914104
Your problem sounds very similar to mine when i installed external coils.
The car was fine off boost, ok up to about 5psi at partial throttle but as soon as i put my foot down i would experience what i could only describe as complete ignition breakdown. No acceleration at all and it happened instantly.
Long story short, i checked everything except the coils (as i bought them new and had seen the exact same model work perfectly on a CA and SR), swapped cas, upgraded fuel pump, ecu swap, ignitor swap, pulled the injectors and cleaned them, replaced all filters, the lot, no change.
In the end out of desparation i wired the stock rooted coils back in and the car was instantly better (but still far from perfect), so i ordered a set of splitfires, installed them and haven't had an issue since.
I think the problem will most definately come down to the coils. If it can be fixed by adjusting the dwell and firing time, great. If not then it may be worthwhile swapping in a set of stockers for a test.
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1915756
Yeah just talk to your tuner about how to do it, on the wolf its straight forward.
My car seemed to breakdown on 17psi at around 6-6500rpm, that was with standard coils. Put a new set of splitfires in and same problem. New plugs 7 heat range i think gapped to .6 and still no change. With charge time set to 4ms the problem disapeared, but was concerned about burning the coils out. So we set discharge to .6ms (it was 1ms before) and this allowed us to bring the charge time down to 2.4ms.
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1915870
Falcon coils use around 3.5ms charge and 0.6 discharge time.(Not sure the PFC will do that)
If your using EF Falcon coil packs then its waste spark and the discharge finds it easyest path and at higher boost thats the plug thats not under compression so it will miss,If your using 6 Falcon coils the Nissan module wont be upto it.
Many ppl run upto 30psi on stock coils so there must be a problem with the coils-ignitor-wiring if they miss fire under load.
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1923827
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
    • Not in any way aroused by any of those, except maybe the big AMGs. And that would break my never a Euro, ever, rule.
