Ok so i have a RB20 and wanting to run over 300rwhp with 20psi
I was stuffing around with coilpacks for ages trying to fix a miss but eventually gave up and have upgraded to a falcon coil pack.
But the miss is still there, even with a 0.55mm gap it still misses a fair bit under boost. When the boost is turned up to 18/20psi it misses of virtually all cylnders.
I have a Power FC and my tuner played around with the coils settings with datalogit but to no avail. I have changed coils/plugs/ignitors etc etc many times and none make a difference
I got my hands on a hand controller a few weeks ago and as the revs got towards the top end (when it starts to miss) the volts dropped on the hand controller read out (14.4 down to 13.2). My friend has a very similar setup to mine so i did the same on his and it stayed a constant 14.4v through the rev range.
So i changed the alternator to see if it was the problem, once again with no luck. Now im going to change the alternator belt as i have been advised that it may be slipping with revs but if this does not work im as a loss of what to do.
does anyone have any ideas about what could be my problem?!?
any help would be appriciated
thanks simon
Edited by Cerbera
https://www.sau.com.au/forums/topic/103874-unfixable-miss/
14.4 is a little high for a warmed up motor.
Generally 14+ is acceptable for a cold motor however once the motor has warmed it will drop to approx 13.8v.
Mine under full load at high rpm will drop to ~13.3v.
I don't have any issues with coils breaking down.
But.. I'm not running any where near as much boost as you.
What plugs are you running?
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1910411
for you to be drawing some nuch current in the electrical system to drop the voltage like this you must a serious issue in the electrical system(it may not even be related directly to the ignition system but is related to rpm).
It might be worth checking the supply wiring to the ignition system poor conducts can brake down under load but still supply an electrical path when not stressed, plus the voltage you reading on pfc make be quiet different to the volt the ignition system is recieving
CHECK THE WIRING LOOM(as it could be a simple as bad supply wire)
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1911300
My suggestion is to do a leak dow test to eliminate rings, pistons and valves as the cause. In the old RB20DET we were running 225rwkw (302 rwhp) at 19 psi on standard coils and copper NGK's at 0.8mm. So you are not looking at anything extraordinary.
:ban: cheers :)
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1911626
ok to answer some questions...
i run bcp6es and bcp6e and they both are the same, might get my hand on a set of bcp7es and try them?!?
base timing is around 15 deg and the timing is a few degrees off pinging top end like a good proper tuner should do (around 13-15) :P
we did put more timing in on dyno but it just caused pinging and knock count was getting on the high side of just under 60
the power running to the ignitor was checked at idle but not under load... may have a check of this again under load
the rings/pistons and valves are assumed to be fine as there is virtually 0 blowbye from the engine plus the fact that the miss goes away if the plugs are gapped low enough...
plugs come out with all normal markings of a good working engine, maybe a tad rich but thats for saftey
grim32, i may give this a try. i shall talk to my tuner, datalogit is used to adjust correct?!?
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1913222
While it may not directly help your issue, make sure you check the real simple things.
I had a similar miss, only showed up under high boost. We replaced ignitors, coil packs, spark plugs so many times it wasnt funny. 4 months later we had it on the dyno (because I had been too lazy to get it properly checked) to try and solve the problem when my mechanic noticed under large boost, an injector o-ring was being pushed up slightly... enough to cause a leak and cause the miss.
An $0.80 part caused 4 months of pulling things on and off of heartache.
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1913294
That caused some serious hair pulling. If you have the car on the dyno have a good listen around the intake manifold, Nik's car made the slightest little whistle and it was only #6 injector that was leaking but caused a really bad miss. It's well worth a look.
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1914104
Your problem sounds very similar to mine when i installed external coils.
The car was fine off boost, ok up to about 5psi at partial throttle but as soon as i put my foot down i would experience what i could only describe as complete ignition breakdown. No acceleration at all and it happened instantly.
Long story short, i checked everything except the coils (as i bought them new and had seen the exact same model work perfectly on a CA and SR), swapped cas, upgraded fuel pump, ecu swap, ignitor swap, pulled the injectors and cleaned them, replaced all filters, the lot, no change.
In the end out of desparation i wired the stock rooted coils back in and the car was instantly better (but still far from perfect), so i ordered a set of splitfires, installed them and haven't had an issue since.
I think the problem will most definately come down to the coils. If it can be fixed by adjusting the dwell and firing time, great. If not then it may be worthwhile swapping in a set of stockers for a test.
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1915756
Yeah just talk to your tuner about how to do it, on the wolf its straight forward.
My car seemed to breakdown on 17psi at around 6-6500rpm, that was with standard coils. Put a new set of splitfires in and same problem. New plugs 7 heat range i think gapped to .6 and still no change. With charge time set to 4ms the problem disapeared, but was concerned about burning the coils out. So we set discharge to .6ms (it was 1ms before) and this allowed us to bring the charge time down to 2.4ms.
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1915870
Falcon coils use around 3.5ms charge and 0.6 discharge time.(Not sure the PFC will do that)
If your using EF Falcon coil packs then its waste spark and the discharge finds it easyest path and at higher boost thats the plug thats not under compression so it will miss,If your using 6 Falcon coils the Nissan module wont be upto it.
Many ppl run upto 30psi on stock coils so there must be a problem with the coils-ignitor-wiring if they miss fire under load.
https://www.sau.com.au/forums/topic/103874-unfixable-miss/#findComment-1923827
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
