hey guys. i have recently noticed a small patch of vaseline type goo on my garage floor. i didnt think anything of it as i have small children but the patch has got bigger. after some investigation i found it on the underside of my car. it is under one of the main suspension linkages ( in front of the back wheel). are any of the bushes filled with goo ? i have recently also noticed a slight clunk from the rear end and i am assuming that the two are connected.
do i have goo in my bush ? :P any one else with a similar problem?
the car in question is a R32 GTR. prices for replacment ? ease of fittment?
thanks guys
kermit
https://www.sau.com.au/forums/topic/103888-strange-goo/
most likely one of your front castor rod bushes (liquid filled) is cracked... standard items are cheap enough to replace.. and on a r32 i'd be looking at the condition of all your suspension components due to age, weat n tear.
if it's the castor rod bushes, i'd recommend some aftermarket pillowball items.. but some people on this site will disagree and say use whiteline offset bushes instead :)
https://www.sau.com.au/forums/topic/103888-strange-goo/#findComment-1910542
it's acid. your car has an alien hiding in the chassis. :P
sounds like a split bush. if it's near the back it could be the cradle bushes, hopefully not; i understand the cradle needs to be removed to replace them but i've never tried it. noltec make solid bushes for the cradle.
'...are you a female...' :lol:
Edited by GTR32
https://www.sau.com.au/forums/topic/103888-strange-goo/#findComment-1913108
two front subframe bushes are filled with silicon, rear two (up by spare wheel well are solid). expensive to replace if you pay someone else, looking at 10 hours labour + parts.
I uploaded a how to on this a while ago, dont know if it ever got into the tutorials tho.
I did it myself, only getting help when I was refitting the subframe back to the vertical bolts. It is a Tricky job but not impossible if you think it through and are careful.
Stephen
https://www.sau.com.au/forums/topic/103888-strange-goo/#findComment-1916099
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
