no need to sign it nemore guys, it has been confirmed lakeside is beeing re-opened as a historic and club racing circuit....
Where can I read about this re-opening ???
I have read the EOI and it looked to me like just another step in the process of closing it down, the existing site reports contained in the document indicated to me that sh*tloads of money would need to be spent to make it a viable option to re-open
I want it open .. only 10 minutes up the road from my place
I didn't know the EOI was part of the condition of an agreement with QLD Heritage Council to have Lakeside's Heritage protection removed until I looked into it further. I thought the EOI was as Council stated - looking for interested parties to run the facility for the communities use.
This is the actual state of affairs at the moment, and it's not terribly promising:
The QHC (QLD Heritage Council) made an agreement with PRSC (Pine Rivers Shire Council) in the Planning and Environment Court of QLD, to deregister Lakeside Raceway from the Heritage Listing in order to help PRSC find a suitable use for this site with the community.
There were a number of conditions to this agreement, including a deadline for PRSC to seek expressions of interest from the comunity as to its future use. That has happened now, and PRSC have until the 29th of March to advise QHC in writing of the outcome of the EOI process. So we will soon hear more about it from QHC and/or LMRE (lakeside MOtor Racing Enthusiasts).
There is unfortunately no commitment in the agreement from PRSC to actually take any action after the EOI, to actually give the community the use of the facility as per the spirit of the agreement. And the site is only protected until May 2010 at this stage.
So any re-opening is by no means guaranteed, and wether it would include motorsport use if it does re-open is also not guaranteed.
:P
ill stand by my comment im sorry you guys dont believe me but there is no reason y i would lie or post up bs information.
They are in the final stages and all they basically have left to do is decide on a tender to run the track. I have my sources take what u like from that.
maybe you should have a read of the agreement PRSC signed with QHC in the Planning and Environment Court. This was the outcome of PRSC appealing the heritage listing of Lakeside.http://www.lakesideraceway.com/p&e_court_agreement.htm
Yes there was an EOI which just closed, but that was a requirement of this agreement PRSC signed to get Lakeside off the Heritage Register. They HAD to do it to achieve their goal of getting the protection lifted from the site. Now that they have done that, there is absolutely nothing binding PRSC to do anything more than that, apart from advise the QHC of the outcome of the EOI process by 29th of March.
I hope you are right and that it is about to re-open, but the fact is PRSC bought the place to shut it down, and have never even showed any interest, let alone made any commitment, to re-opening it for motorsport.
Call me a cynic, but I think now that PRSC have completed their obligations under the agreement, and have won their appeal to have Lakeside removed from the Heritage register, they can get on withthe business of closing the place down. And in 4 years time they can take the bulldozers in.
I know a few people around the place on CAMS State Council, in PRSC, in the Historic Racing Car Club etc, and I haven't heard any rumours of this re-opening being imminent.
Edited by hrd-hr30
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
