Does nissan put in oil restrictors to the turbos on the n1 engines? I have changed from a standard block to an n1 and am using n1 oil pump with 34 n1 turbos. connecting this all with my standard r33 gtr oil lines. All im looking to know is that when a r33 or 34 n1 rolled out of the factory were they fitted with oil restrictors..?
Good question! Can I also add to your question by asking who makes said oil restriction kits if the N1 blocks don't already have one fitted?
Tomei...contact Ian @ Hi Octane....or in QLD Mark @ Godzilla Motorsport.
Edited by DiRTgarage
What oil restrictors are you talking about?
The one between the block and the head?
The N1 blocks we have received did not come fitted with oil restrictors, you have to fit them.
Or the restrictor in each tubo oil inlet?
The new R34 N1 ball bearing turbos we have received did not come fitted with oil feed restrictors, you have to fit them. Used ones did.
:) cheers ;)
All BB turbo's require a restrictor of some sort.
Or else the turbo will get to much oil and blow seals etc.
The restrictor is usually in the banjo fitting on the oil lines running to each turbo.
Hope thats what you are asking.
  • 1 month later...
Just found this post when doing a search on a question that I'm looking for the answer to. It's essential to fit an oil feed restrictor to the turbo, but is the one i have purchased in the link below suitable for my GT30/40R?
http://www.himni-racing.com/index.php?main...products_id=508
(in my setup, i'm using an N1 oil pump on an rb25det)... If this is installed, is it still essential to put a restrictor in one of the two oil feeds on the block, going to the head?
Edited by silman
Im pretty sure all BB turbos (genuine ones) from garrett and hks have inbuilt restrictors. Therefore no need for this restrictor for your "mismatched laggy" gt3040r. Disco could confirm this. Let us know how this turbo goes cause apparently, they are laggy :no:
Please take the time to read my post carefully and reply only if you have information relating to this question. There's a lot of talk about GTBB turbo's having restrictors inbuilt that's clear from the amount of threads on the board. My post clearly specifies though, that I have an N1 oil pump, and i have this external oil feed restrictor.
Sydneykid or someone with first hand experience, can you please confirm that with all RB engines, is a restrictor on the block still required if a 1.5mm turbo oil feed restrictor for the turbo is in place? (1.5mm in my RB25 application). Does the location of the restrictor make a difference to oil starvation at the sump? Or does the restrictor HAVE to be installed in the block, leadng to the head ONLY? cheers.
Edited by silman
You sure are confused…………….let’s see if I can fix that…………….
1. There is no relationship between the restrictor in the block to decrease the oil flow to the head and the restrictor in the turbo oil feed.
2. The turbo oil feed is plumbed into the block BEFORE the head feed oil restrictor. So the size of the head feed oil restrictor has no effect what so ever on the turbo oil feed.
3. The size of the head feed oil restrictor is ONLY dependant on the oil pump used and the RPM that the engine sees. The turbo (plain or ball bearing) has ZERO effect on the size of the head feed oil restrictor.
4. On RB’s, all ball bearing turbos require an oil flow restrictor because the pipework and fittings are designed for plain bearing turbos. Plain bearing turbos require significantly more oil flow than ball bearing turbos.
5. Ball bearing, water cooled turbos require less oil flow than plain bearing oil cooled turbos
6. SOME ball bearing turbos come with oil flow restrictors standard, some DON’T. Some have add in restrictors, separate parts that you can remove. Some have the oil feed drilled to the right size (ie; no external restrictor is required). Look in the oil feed on the turbo core, if the hole is larger than 2 mm there is no restrictor. If the hole is smaller than 2 mm, then that is the restrictor you are looking at.
Hope that helps
:D cheers :D
thanks for clearing that up. I'll take the head off, and install a 1.5mm restrictor in one of the feeds in the block whilst the engine is out of the car. By the way, here's a picture of my turbo. It looks like it doesn't have the restrictor installed (does this seem to be the case from what you see?), but i'll use the one i bought pictured above at this fitting.
and the other side;
Edited by silman
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
