Does nissan put in oil restrictors to the turbos on the n1 engines? I have changed from a standard block to an n1 and am using n1 oil pump with 34 n1 turbos. connecting this all with my standard r33 gtr oil lines. All im looking to know is that when a r33 or 34 n1 rolled out of the factory were they fitted with oil restrictors..?
Good question! Can I also add to your question by asking who makes said oil restriction kits if the N1 blocks don't already have one fitted?
Tomei...contact Ian @ Hi Octane....or in QLD Mark @ Godzilla Motorsport.
Edited by DiRTgarage
What oil restrictors are you talking about?
The one between the block and the head?
The N1 blocks we have received did not come fitted with oil restrictors, you have to fit them.
Or the restrictor in each tubo oil inlet?
The new R34 N1 ball bearing turbos we have received did not come fitted with oil feed restrictors, you have to fit them. Used ones did.
:) cheers ;)
All BB turbo's require a restrictor of some sort.
Or else the turbo will get to much oil and blow seals etc.
The restrictor is usually in the banjo fitting on the oil lines running to each turbo.
Hope thats what you are asking.
  • 1 month later...
Just found this post when doing a search on a question that I'm looking for the answer to. It's essential to fit an oil feed restrictor to the turbo, but is the one i have purchased in the link below suitable for my GT30/40R?
http://www.himni-racing.com/index.php?main...products_id=508
(in my setup, i'm using an N1 oil pump on an rb25det)... If this is installed, is it still essential to put a restrictor in one of the two oil feeds on the block, going to the head?
Edited by silman
Im pretty sure all BB turbos (genuine ones) from garrett and hks have inbuilt restrictors. Therefore no need for this restrictor for your "mismatched laggy" gt3040r. Disco could confirm this. Let us know how this turbo goes cause apparently, they are laggy :no:
Please take the time to read my post carefully and reply only if you have information relating to this question. There's a lot of talk about GTBB turbo's having restrictors inbuilt that's clear from the amount of threads on the board. My post clearly specifies though, that I have an N1 oil pump, and i have this external oil feed restrictor.
Sydneykid or someone with first hand experience, can you please confirm that with all RB engines, is a restrictor on the block still required if a 1.5mm turbo oil feed restrictor for the turbo is in place? (1.5mm in my RB25 application). Does the location of the restrictor make a difference to oil starvation at the sump? Or does the restrictor HAVE to be installed in the block, leadng to the head ONLY? cheers.
Edited by silman
You sure are confused…………….let’s see if I can fix that…………….
1. There is no relationship between the restrictor in the block to decrease the oil flow to the head and the restrictor in the turbo oil feed.
2. The turbo oil feed is plumbed into the block BEFORE the head feed oil restrictor. So the size of the head feed oil restrictor has no effect what so ever on the turbo oil feed.
3. The size of the head feed oil restrictor is ONLY dependant on the oil pump used and the RPM that the engine sees. The turbo (plain or ball bearing) has ZERO effect on the size of the head feed oil restrictor.
4. On RB’s, all ball bearing turbos require an oil flow restrictor because the pipework and fittings are designed for plain bearing turbos. Plain bearing turbos require significantly more oil flow than ball bearing turbos.
5. Ball bearing, water cooled turbos require less oil flow than plain bearing oil cooled turbos
6. SOME ball bearing turbos come with oil flow restrictors standard, some DON’T. Some have add in restrictors, separate parts that you can remove. Some have the oil feed drilled to the right size (ie; no external restrictor is required). Look in the oil feed on the turbo core, if the hole is larger than 2 mm there is no restrictor. If the hole is smaller than 2 mm, then that is the restrictor you are looking at.
Hope that helps
:D cheers :D
thanks for clearing that up. I'll take the head off, and install a 1.5mm restrictor in one of the feeds in the block whilst the engine is out of the car. By the way, here's a picture of my turbo. It looks like it doesn't have the restrictor installed (does this seem to be the case from what you see?), but i'll use the one i bought pictured above at this fitting.
and the other side;
Edited by silman
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
