Heya all,
My 32 is potentially showing more problems... :ban:
Just noticed my Apexi pen-style turbo timer is showing fuel ratios around the 10
mark on full boost. Is that ok, are am I facing detonation? Only mods to the car
are a 3" catback exhaust, blow off and sports filter insert.
On idle, the ratio sits around the 14.5 mark, and when I gear down it gets as high
as 18-19.
Any help or comments are greatly appreciated. B)
Thanks,
Adrian.
https://www.sau.com.au/forums/topic/103937-apexi-timer-showing-low-fuel-ratios/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
